Question about Philips Magnavox 60PP9701 60" Rear Projection Television
Philips Magnavox 60PP9701 60 in. Rear
When the light colors are on the screen the picture gets smaller
I have a Philips 60pp9701 rear projection TV. I need to replace the crt bulbs and need step by step instructions on how to access them, purchase them and replace and adjust them.
Posted on Dec 05, 2009
  • Philips Master
  • 3,459 Answers
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jul 16, 2008
    President:
  • 1,284 Answers
If the picture is changing size when bright images appear on screen, then a power regulator issue is what you have. Have a technician look at it.
Posted on Feb 23, 2007
Philips Magnavox 9P6040CI ? Alignment ?
you have to set up the convergence using the on screen pattern generator.
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 9p6034c 60 in. rear projection t.v.
are you sure!? or maybe you set at the pip viewer! go to settings!
Oct 01, 2007 | Philips Magnavox 9P6034C 60" Rear...
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto www.magnavoxhelp.com to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
My Philips Magnavox 9P5511C102 color is faded and not clear. The colors seem faded (off) tv is not clear, like is got static, and picture is shaky. I have tried to fix using the Main Menu already. Out of...
update the firmware/software if possible. my 60" has a USB slot on the right side. also you can download the manual from phillips http://www.support.philips.com/support/html/index_us_en.html#../~scripts/xsltransform.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=us_en||mode=cats||item=TV_GR&xsl=subcatalog.xsl
my phillips 60PP9200D/37
Apr 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips rear projection color and pic problems
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color lights show thru screen
check for loose wires and check that all the connectors are tight.
Jan 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60 in. Rear... Problem
I had a similiar problem. My screen would shrink in then expand. After a few months of doing this it just broke altogether. No sound or video.  Its not fixed.
You can get a repair kit from this site.
http:///www.magnavoxhelp.com
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 60PP9701 60" Rear Projection Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
