Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000 won't print
I just changed the ink cartridge on the above printer and now it won't print anything. I am using a canon cartridge and i replaced the print head about 2 months ago. The last cartridge worked fine. I'm sure I am putting it in correctly. Please help. Thanks
  • pblack550 Dec 12, 2008
    Printer will not print, light just keeps flashing green to yellow
  • 23 Answers
Check usb cable if they are installed firmly and correctly. Check proper voltage input though designed as Autovolt system.
Try plugging the usb cable on another free usb port or you may try another computer to check if your printer works.
See if there are blinking lights and error codes. You can google for its error codes.
Check flex cable continuity, maybe some rodents have eaten it.
Remove ink cartridge, turn the power off and clean cartridge contacts including the holder contacts, turn it on and return cartridges. You may try borrowing a working ink cartridge of the same type from a friend.
Posted on Dec 24, 2008
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
I keep on getting Ink System Failure for HP 309a inkjet printer. I tried to clean the printer head still no lack.
Most likely, it is a print head issue. The print head is what the printer cartridge sit in inside the printer. To fix the problem, please do the following:
1) Open the printer and wait for the carriage to slide over.
2) Remove the ink cartridges from the print head.
3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to clean the printer head and electronic contacts on ink cartridge.
4) Repeat the same procedure until no ink residue coming off on the cotton swab.
5. Once finished, allow to dry and put back the ink cartridges in.
6. Try printing.
If the above troubleshooting won't work then maybe one of the cartridges is defective or both. If none of the cartridges are defective, then you need to replace the print head.
I hope this helps.
carlo
Nov 16, 2012 | Office Equipment & Supplies
What is error B200 when attempting to power up
http://www.printerdiary.com/2011/09/canon-error-b200-how-to-fix-it.html
Error B200 on Canon printers is a print head error. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Mar 24, 2012 | Office Equipment & Supplies
Won't print black, prints every other colour ok
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck....
Jun 19, 2011 | Canon Pixma MP500 All-In-One InkJet...
Changing or cleaning printer heads
Do not touch print heads with anything or you will damage and/or plug the ink holes. If print head is removable then: boil distilled water in shallow dish in microwave, immerse print head in water for 10 minutes, blot on cotton lint free cloth, reinstall in printer, then run print head clean utility. Repeat if necessary. If print head is not removable, check if there are ink jet holes on the bottom of the ink cartridge and do the same as above.
Aug 26, 2009 | Canon Office Equipment & Supplies
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Print head
That is a strange message unless you have changed the print head recently (or it has become defective). The first thing I would do is try reseating the print head.
Unplug the printer.
1) Remove the 5 ink cartridges.
2) Lift the lever that is just to the left of where the ink cartridges sit. This is the print head lock level.
3) The print head is located under the ink cartridges (if they were still there) lift it out carefully.
4) Inspect for damage but do not touch anything or it can cause problems.
5) Carefully replace print head and lower level until it clicks
6) Replace ink cartridges
Plug in the printer and test.
If you still have a problem -
Call 1 (800) 828-4040 for warranty part replacement or to order a part out of warranty.
Oct 06, 2008 | Canon MP830 All-In-One Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
240 people viewed this question
old marine
old marine
