Question about InFocus ScreenPlay 7200 Multimedia Projector
In 72 power board
Where you able to locate and purchase a new power board?
  • 74 Answers
No need for a new power supply I can repair them at a lower cost. My ebay ID is Gtitubro.
Posted on Feb 11, 2009
    Problem Solver:
  • 6 Answers
I just got back my power supply that Neo32/gtitubro repaired. He did a great job, I'd recommend him. I had first tried several sources to get the power supply board, but both were unable to get it, so I was ready to junk the PJ before I found this board, he repaired it cheaper than it would have been to get the new board if it had been available.
Posted on Aug 19, 2009
Need location to buy replacement circuit boards or parts lists for circuit boards
many components can be sourced from shops like Jaycar or the like
try the manufacturer for a complete board or a schematic of the board
Dec 29, 2015 | Tenma 72-6340 Vacuum Desoldering Station
Delonghi EAM3500 problem in power board (part no 5232109900)
There are lots of Delonghi spare parts on the website komtra
Unfortunately the page is in German.
A new Power board is available for 72 euro
Dec 03, 2013 | Coffee Makers & Espresso Machines
How do I purchase a new controller board for the HD250UES-72 case?
The easiest way would be to buy another external hard drive case off of ebay or computer store.
Sep 30, 2017 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Blower continues to after reached temp
Sounds like either a short between the G and R t stat wires or the relay in the control board is faulty. Easy way to check is remove the G wire from G terminal on the control board, if the blower stops, there is a short in tje t-stat wiring, if it continues to run a new control board will be needed since the relay is part of the board.
Jan 08, 2013 | Honeywell TH4210D1005 Heater
I have a Panasonic CF_72 toughbook it is no charging the battery, I bought a new battery and have power to the mother board but it's not getting voltage to the battery to charge it. I was told there is...
This is just a suggestion, but some Dell Computers use an AC adapter which sometimes power the computer but do NOT charge the battery pack.
Simply trying another different power supply or AC Adapter will fix the problem without changing the voltage regulator.
I hope this corrects your problems.
Good Luck and regards from:
Richard, Montreal Based Panasonic Canada Toughbook Authorized Dealer since 1989.
Oct 24, 2017 | Panasonic Toughbook 72 Notebook
72 in shuts off 3x every 10 min.new bulb 7 th one mitsubishi 72 in
You need to check on the power supply board for Bad Capacitors they will be vented,swollen, or puffed up on Top. 680uf 10v,330uf 10v 3300uf 10v 2200uf 10v,
Sep 01, 2010 | Mitsubishi WD-73927 73" HDTV
We have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Mar 04, 2010 | Ovens
Where do i find the starters for the florescent lights on a true gdm-72
They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
Nov 12, 2009 | True GDM-72 Refrigerator
Model HD160U2E5-72 s/n A0575461 is dead
Remove the actual hard drive from the case. Purchase a new external usb case for the drive. You can find them on the web from 7 to 29 dollars. Make sure you buy the right case for the drive 2.5 or 3.5 inch E-IDE or SATA ect. Install the hard drive from the old unit in the new case and you should be back on the road in no time.. Hope this was helpful....
George
Jul 15, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
InFocus ScreenPlay 7200 Multimedia Projector Logo
589 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
