Question about Bionaire W7 Humidifier
Hunidifier doesn't add enough moisture to air
The fan runs fine but only one tank of water used every 4 or 5 days. Filter above water line becomes dry when fan runs a while. Can't get humidity above 28% when machine is set at 40 percent. Thanks for your help. Dale
  • Dale Brown Mar 08, 2007
    Any input for this problem yet?
  • 944 Answers
Here is the link to the manual for the w7 - they suggest a replacement wick filter would solve the problem due to bacteria or mineral build up - i would expect this to solve your problem as the only way these wicks can not soak up the water to the top is if they are clogged or the tank is empty. try the cleaning routine on page 9 first - might be enough but the wicks probably will need replacing soon anyway. http://www.bionaire.com/manuals/W7_English.pdf Hope this helps :)
Posted on Mar 10, 2007
I have Bemis (Esswick) Humidifier Model # 4968. The motor runs fines however I can't get the humidity in my above 30%. I changed the filter and it was close to 45% for a few days but running continuously,...
You should be able to get a higher humidity rate at normal settings. If you want high humidity above 40% that should be easily done with the high speed operation. The unit may need a good internal cleaning, and use a Vinegar solution to clear any Calcium or other mineral deposits from the misting ports and misting elements. You must use only Distilled or Filtered water, not tap water.
Jan 29, 2018 | KwikFilters.com Bemis 4968 Humidifier Wick...
I have a 2 yr old dehumidifier and it runs, it just won't pull out the moisture out of the air.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(No LED screen), set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you and thanks for choosing FixYa
Sep 13, 2011 | Kenmore 938060 Humidifier
Wont run in unit lift out and lift level control works fine put it back in unit [ very tight fit] lift level control wont work
Hello.
The GE humidifier adds a continuous stream of cool mist intothe air, giving moisture to dry air due to cold weather or dry climate or tohelp those who desire additional moisture because of respiratory problems orallergies. Sold online and in many department or home retail stores, thehumidifier requires regular cleaning and maintenance for proper functioning andto help keep mineral scale or bacteria from growing in the humidifier. ·1 Connect the power cord on the GE humidifier firmly to a power outlet if thehumidifier is not working. Replace or reset the circuit breaker as necessary.Turn the power switch to "On" if there is power but the unit is notoperating. · 2 Fill thewater tank to the "Fill" mark if the mist output is low or notpresent. Wait 15 minutes after filling the tank and before starting thehumidifier to allow the wick filter to absorb the water for proper function.Turn the humidistat knob to a higher setting for higher output. · 3 Check the capon the water tank and close the cap firmly. Check the rubber tank cap ring onthe cap and reseat firmly to help provide a better seal. · 4 Replace thewick filter with a new wick filter, available through General Electric, if thewick filter inside the base turns brown. Replacement parts may be ordered bycalling 877-207-0923. · 5 Clean thewater tank with vinegar and a soft brush if the water begins to get cloudy.Rinse well before refilling with water. Use cold water in the tank, as warm orhot water may make the water appear cloudy. · 6 Loosen thetank cap slightly if the humidifier cycles on and off unexpectedly. Turn theknob to a higher or lower setting. Thanks.
Sep 09, 2011 | Sunbeam Humidifiers
DEHUMIDIFIER IS RUNNING BUT NOT COLLECTING WATER
level
problem.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 28, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
Our Kenmore 50pt dehumidifer is less than 2 years old, only used for 1 summer, tried to use it last week, it starts/runs but does not withdraw any water, please help. Thanks kindly
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you unit is manual control,
turn the control knob to Maximum.
the unit without the filter. Filter should be cleaned once every 2 weeks.
level
problem.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Humidifiers
The humidifier appears to be working (with sound ) but is not collecting any water-cleaned the filter and still the same -the lit up area where it usually has the numbers is sitting at P2- I have lost the...
Alison -
A humidifier will not collect any water. A humidifier has a tank that you fill with water. The water is released / forced into dry air to make it moist, usually by a fan or ultrasonic method.
A dehumidifier has an empty tank that gets filled by the appliance extracting moisture from the air. The tank will have to be manually emptied periodically, otherwise the safety / water level switch will shut the unit off so that the tank doesn't over flow.
I suspect that you meant to say dehumidifier.. and if so, please provide the manufacturer's name and model. The "P2" indication will be difficult to interpret without knowing the manufacturer's info.
Nov 22, 2010 | Humidifiers
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 04, 2009 | Hunter CareFree Plus 33222 Humidifier
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Bionaire W7 Humidifier Logo
389 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
