Question about E-Machines M5305 Notebook
Removal of eMachine M6410 optical drive
I must be missing some screws, unless there's a trick to removing the back of the PC, in order to get to the optical drive. I replaced a defective harddrive and now the optical drive will not boot my XP disks. I want to replace the optical drive, but am having difficulty with the back of the notebook where the monitor connects.
Either I am missing some screws or there is a trick to removing it so I can access the optical drive.
Can you assist?
  • wtjqwpt Dec 08, 2008
    It worked! thx
    Scholar:
  • 68 Answers
There are two small screws that the monitor cable would screw into, these have to be removed (7mm i believe) to be able to remove the base. The optical drive will typically pull out of the side after a screw has been removed and latch has been opened. I wouldn't go as far as removing the entire base.
Posted on Dec 08, 2008
I've got yuyun_cantix icon on my desktop. Could you ,please help me with this problem? Thanks.
not a real description of the problem
try this
right click on the icon and in the drop down box--- delete ---
the program will still be on the computer
if however you wish to remove the problem entirely--go control panel-- go programs -highlight yunyun line-- click uninstall and then when finished go to the icon on the desk top and follow the first instruction
Jan 09, 2017 | Icon Computers & Internet
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
How do I delete facebook?
You can definitely delete/remove/deactivate your account/profile/page from Facebook. In short you can escape from Facebook, but you can't destroy it!
Please go through the below link if you would like to remove your account.
Facebook - Delete your account
Fort Networks.
Jun 20, 2014 | Computers & Internet
How do I get the battery out of my acer laptop
Your Model of Aspire has a different battery release method, see attached pic on how to do it. This is a pic from your User Manual, you can download it from here Download Acer Aspire E1 572
Manual
. I suspect that the information you have been given regarding battery removal and passwords refers to removing the cmos battery as in a PC in the hope that it will clear Bios activated passwords.
May 04, 2014 | Computers & Internet
I have an imac computer model M6498EMC that is without a hard drive.I have all kinds of sata and ide drives.can i install one of these and how do i do it exactly
You will find at the bach of the PC there are little 'doors' with screwed covers. find an empty slot slide drive in and screw down then connect up inside to the loom on a spare socket
Sep 27, 2013 | Computers & Internet
Hide file folder WITH A password
For the most part you need 3rd party software, or a USB drive with security built in. Just remember you are at the mercy of those companies if you lose the password. Plus some software will only works locally. For instance if someone removes the drive and connects it to another computer the files are wide open.
Win 7 Ult and Ent (high end editions have Bitlocker built in.
A simple way is to create a folder within his login account docs and choose hidden as the properties. The only way to see it would be to change folder properties and make hidden files visible. This is just cloaking, because anybody with admin rights can see them.
May 09, 2013 | Gateway NV5215u Notebook
Removing bluetooth chip
Without knowing what the desktop computer motherboard is, I\'d only be guessing as to location of Wi-Fi chipset.
However even if I knew the motherboard manufacturer name, and model number; the point is Moot.
A) You remove that Wi-Fi chip, and kiss the motherboard goodbye.
It\'s designed into the circuitry of the motherboard.
Isn\'t going to be jumper wires taking it\'s place, and making connections to circuit traces on the motherboard.
B) Do you have a wireless router?
Dunno.
Do you have a wireless connection set up?
No.
You can use just a LAN connection. (Hard wired)
C) Suggest if having a Bluetooth option on your motherboard is not an option then use a different motherboard that doesn\'t have that option.
Regards,
joecoolvette
Apr 06, 2013 | Computers & Internet
Don't start up
check that all removable media is removed from computer, flash drives etc,if this message still appears the reinstall your os, there are several reasons for this error. You may have to replace your hard drive if that is the issue- you would know because after reinstall (if it makes it thru it) it will only crash again, this is much too big of a subject to sum it all up here and now, good luck... more questions just ask
Mar 30, 2013 | Computers & Internet
C:\preload\data9_04.inp cannot be recovered
You can recover the file with 3rd party data recovery software.I have succeed to recover files from external hard drive with Tenroshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost files. By the way,you can download it and scan your hard drive for free to preview whether your file can be recovered. Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Jul 31, 2011 | HP Media Center m1080n (PC099A#ABA) PC...
I can't find the radio switch on my toughbook to activate wifi. I tried the yellow icon on the bottom right, but the wireless and bluetooth options are grey (cannot be selected) Thanks, Dave
http://pc-dl.panasonic.co.jp/dl/download/file/16957/s/28ef6385388fe6ee/19mk3_30mk3_52mk2-si4hspa-cpe02197za-xpvista7-M.pdf
Page 4
Russian admins and Google Rules!
Feb 07, 2011 | Panasonic Toughbook 19 Laptop Convertible...
E-Machines M5305 Notebook Logo
111 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
