Question about HP Pavilion dv6000z Notebook
Task-bar & start-menu disappeared
My computer is actually HP Pavilion dv6000, without the "z" at the end.
I turned on the computer, the resolution changed by itself & ended up with big desktop icons. I changed the resolution back to the standard resolution: 1280x800. I restarted the computer, somehow all the desktop icons, task-bar & start-menu (except the side-bar & the desktop background image) ''disappeared''. It seems that all the desktop icons, task-bar etc, sort of has gone beyond the screen. I logged on again using safe mode & tried different resolutions, none worked.
I appreciate it if anyone can help.
  • 3 more comments
  • cen88 Dec 09, 2008
    thanks wigglybus. the drivers are installed. i've been using this notebook for over a year. got no external monitor, guess i'll take it to the shop. glad that the warranty is for two years in europe. if it's a video card failure & it is attached to the motherboard, i seriously hope that they would give me a new notebook in replacement, fingers crossed though. will let you know if your diagnosis is right. thanks again.
  • cen88 Dec 11, 2008
    I took it to the shop & was told that it's not video card problem. The guy there attached an external monitor to my notebook & 'fixed' the problem only at that moment. The same problem reappeared after restart. (PS: warranty covers only hardware problems)
    Could this be a virus/hacking situation? If I reinstall the system (vista home premium), would it get rid of the suspected malicious program?
  • cen88 Dec 12, 2008
    video card = graphics card (mine's NVIDIA GeForce Go 6150)?
    Sorry, more questions.
    1. once the video/graphics card is uninstalled, would I get a blank screen?
    2. So that I have to shut down the notebook by pressing the power button?
    3. Do I have to choose between safe mode & normal mode? If yes, which?
    4. Where does windows find the video card? On line? But the notebook gets no internet connection (I have only wireless lan) in safe mode; in normal mode, there is no task bar to be seen. Even if I am prompted to install the video card again, I wouldn't know it since the the display is sort of "off-screen".
  • cen88 Dec 20, 2008
    Normal
    0
    21
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-fareast-font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Hadn’t got time to fix it till last
    night. It worked! Thanks.
    Everything's fine except that words (text in general) are not as sharp as
    before, sort of blurry, thicker & possibly a little bit “squeezed” on both
    sides. Setting back to original resolution 1280x800 didn’t help. Any advice on
    how to fix it?
    The Display Control Panel shows two options: multiple monitor (with PnP
    and non-PnP options) and non PnP monitor. Non PnP monitor labelled 2 (with big
    resolution: 1920x1080) is not active. Multiple monitor labelled 1 is active and
    is set as primary. Is it part of the above-mentioned problem? How can I set the
    display to PNP monitor instead of multiple monitor?
    Thanks very much again for your time.
    Scholar:
  • 86 Answers
Just do as I say - it will be ok and sort itself out - the screen will not go blank and the drivers are still installed in Windows and will just be reinstalled, thus associating themselves with the card again. No internet connection is needed and the drivers will be reinstalled automatically without the need for user input.
To gain access to that which is 'off screen' push the mouse against the edge of the screen and it should move the display into view
Posted on Dec 12, 2008
    Scholar:
  • 86 Answers
Sounds as if the video card is going down. This is a common problem on these laptops. Have you checked Device Manager to see if the drivers are installed. Hit Win key and pause then select hardware and Device Manager. If nothing seems out of place there then I would most certainly suspect the video card. This is part of the motherboard and not replaceable.
As another check try connecting the laptop to an external monitor via the VGA connector at the back. The resolution problem should be resolved then.
Posted on Dec 08, 2008
  • wigglybus Dec 11, 2008
    OK
    lets assume it is a video card problem but a software one and not hardware
    find the video card and right click to uninstall in
    when that has finished shut the machine down, disconnect all power (unplug it - not forgetting to remove the battery too). Leave for 10 seconds and then
    reconnect and reboot the machine and let windows find and reinstall it
    If it is a driver association problem then that should sort it out
    it sounds as if all he did was to reset the resolution to suit the screen without fixing the cause of the problem.
    regarding virus - have you thought to do a scan to check the system? I doubt if it is that but give it a go anyway. Download Malwarebytes and run that as well as your AV
My HP Pavilion dv6000 screen goes dark when booting up.
Video card/drivers/wiring. Have it starting in safe mode. If the simptoms are similar, have it checked in service. You may need to replace video card.
Mar 06, 2013 | HP Pavilion dv6000z Notebook
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
Feb 05, 2013 | Lenovo ThinkPad T410 Notebook
HP Pavilion DV9925nr LCD shows color distortion.
go to start menu type in search bar adjust screen resolution then click on advanced settings should find what u need there
Jan 04, 2013 | HP Pavilion dv9925nr Notebook
Taskbar has disappeared and the text has gone very small. Can you help hp pavilion home pc. Windows XP
This may be due to the resolution problem.
right click on Desktop -> select Properties
There under settings tab, reduce the resolution using the slider and click ok.
Now you should be getting display as usual.
Using the control on your monitor, adjust the display to show the task bar, in case hidden due to improper settings.
I hope this is helpful in solving your problem.
Please rate the solution provided.
Thanks
Mar 10, 2010 | Computers & Internet
The graphic software failed. no display
When you turn the computer on, do you see the HP logo?
If you don't, keep the computer on and try holding the computer screen under an overhead light at an angle. If you see a faint image of anything on your monitor, then the lights in your screen went bad. A new screen can range $100-$200 on eBay, and can be changed out easily with a small Phillips screw driver.
If you can see the HP logo, it's a driver problem. If this is the case, start the computer in Safe Mode by performing the following steps.
1. Make sure the computer is turned off.
2. Wait for the HP logo disappears and start pressing "F8" repeatedly.
3. A menu will appear. Select "Safe Mode" and let it boot up to the desktop.
4. Once at the desktop, hold down the "Windows Logo" key on the keyboard and press "r". A dialog will pop up.
5. Type "devmgmt.msc" without the quotation marks and click ok.
6. Click the "+" next to "Display adapters".
7. Right-click each entry under "Display adapters" and select "Uninstall" Click OK on the box to confirm. Don't worry, Windows will reinstall it after a reboot.
8. Once all entries are removed from "Display adapters", the category will disappear from Device Manager. Reboot the computer and start it normally.
9. Your screen will probably still be big and blurry. Log into Windows and adjust your resolution to fit your screen. If you select the wrong resolution, and your screen goes black or does not fit, DO NOT PRESS ANYTHING or you will be going back to step 1. The computer will revert back to the old setting after 15 seconds.
10. Once you figure out the right resolution setting, reboot one more time to make sure that the settings took effect, and you can use your computer once again. :)
Oct 25, 2009 | HP Pavilion dv6000z Notebook
Hp laptop, dv6000 series..volume button gone pink!
Usually when the volume button is pink(orangey) it means that the volume has been muted. Make sure both on the quick play bar right of the power button and in the task bar, that the volume has not been set to mute. Also check the audio drivers and make sure the drivers haven't been corrupt and reinstall or re-download new updated drivers in needed.
Aug 27, 2009 | HP Pavilion dv6000z Notebook
Process smartmenu.exe has a volume bar that
first of all u have to remove it from ur startup menu then search any service which support this process and remove it from ur startup Services.
procedure:
window+R
type msconfig and press OK
do above procedure
Aug 03, 2009 | HP Pavilion dv7-1240us Notebook
Start Menu & Taskbar do not appear
How are you accessing Control Panel without a Start Menu or Task Bar? You may want to check/adjust your screen resolution in Display Settings.
Apr 19, 2009 | GE Computers & Internet
HP Pavilion dv6000
hi
Dude very simple, uninstall the graphic drivers completely and reinstall them.
do give me feedback
bye
yasir sardar
Feb 27, 2008 | HP Pavilion Notebook
HP Pavilion dv6000z Notebook Logo
216 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
