Question about Epson Perfection 4490 Office Flatbed Scanner
EPSON Scanner 4490 Problem
Since my laptop crashed, I am unable to launch Epson Scanner (where I get the option to save to .jpg or .pdf. I press the scan button and nothing happens. I get the Epson Scan window, but no dropdown options. I tried un-installing & re-installing the TWAIN driver, but nothing works. It is not a hardware problem, because scanner works if I go thru "scanner & camera wizard".
  • 1 more comment
  • ywork Dec 12, 2008
    1)Delete Epson registry key*
    2) Uninstall Epson Scan program
    3)Shut down pc & re-start
    3)Re-install Epson Scan program & make sure scanner is connected to your pc.
    *Deleting registry keys
    Click on START and then RUN.
    2. In the Run window type in REGEDIT.
    3. In the upper menu bar click on FILE, then EXPORT.
    4. In the window that comes up, SAVE IN should be set to DESKTOP.
    5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
    6. EXPORT RANGE should have a dot next to ALL.
    7. Click on SAVE.
    8. Look in the column on the left and Click on the + sign next to HKEY_CURRENT_USER
    9. Click on the + sign next to SOFTWARE
    10. Click on the + sign next to Epson
    11. Look for a folder name EPSON SCAN. Right click on it and Delete it (if you don't see it, then don't worry about it).
    12. If you see a reference to your Epson product model, right click and delete it.
    13. Click on the - signs next to EPSON, SOFTWARE, HKEY_CURRENT_USER to close up this branch.
    14. Click on the + sign next to HKEY_LOCAL_MACHINE
    15. Click on the + sign next to SOFTWARE
    16. Click on the + sign next to Epson
    17. Look for a folder name EPSON SCAN, Right click on it and Delete it (if you don't see it, then don't worry about it).
    18. If you see a reference to your Epson product model, right click and delete it.
    19. Click on the - signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to close up this branch.
  • sbolton433 Feb 28, 2009
    I have an Epson Perfection 4490. It worked fine until about 2 weeks ago. Now, when I try to start it, the start up image appears but then goes down to the bottom of my computer screen and sits there.
    I can use the "paint" program that comes with Windows XP, but I can not use the controls like I would like to.
    I have called Epson and they said it was Dell's fault. I called Dell and they said it wasn't there problem and that it would cost 129.00 to fix it.
    Irritating.
    Thanks
  • sbolton987 Feb 28, 2009
    nCleaner is safe to run on my machine? I have other anitvirus software. Do I have to disable that?
    What is the Epson Copy Factory Update?
    Thanks
    sb
  • 827 Answers
So you've completely ininstalled. Now you should download and install nCleaner, and do a Clean System, and then a Clean Registry. Now:
Download and install the latest 4490 driver software from here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
The Epson Copy Factory Update may be of some use to you also.
Hope this helps
Chris (ziraffa)
Posted on Jan 11, 2009
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
Epson problem
Here is the download page
http://www.epson.co.uk/Store/Scanners/Epson-Perfection-4490-Photo/Drivers-Support?supportLandingPage=true
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
Unable to open Epson Scan in 4490
try to uninstall and reinstall your printer software
Jul 17, 2009 | Epson Perfection 4490 Film / Flatbed...
Can't scan slides on Epson 4490
Please make sure that the option cable on the back of the scanner is seated properly.
You may need to trash and re-install the drivers.
To get the most recent driver compatible with your operating system, please log on to epson.com and go to the drivers and support page.
Apr 28, 2009 | Epson Perfection 4490 Photo Scanner...
Epson 4490: where'd my "film" option go?
Make sure the lid is plugged in. There is a cord on the back of the lid that plugs into the back of the scanner body.
Feb 13, 2009 | Epson Perfection 4490 Office Flatbed...
I have just bought an Epson 4490 flatbed scanner and want an owner user manual as this is a new machine and there was no real instructions on how to operate the Epson 4490
Here's the Epson Support page for your scanner. Just click on the Manuals and Documentation link for all the available information about the 4490:
It's possible that the Tutorials and the FAQs will be more useful to you..
Fixya!
Chris (ziraffa)
Jan 11, 2009 | Epson Perfection 4490 Office Flatbed...
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
Epson Perfection 4490 Office Flatbed Scanner Logo
435 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
