Question about Amerock Hardware & Accessories
I need a backset replacement for a 1980's Atrium Door.
This door has wider than normal glass panels which resulted in a "stubby" lever with a 2" backset. The backset and working parts of the door are one piece. I've been told that Atrium Company quit making them and National Lock made them for a while and then their operation was taken over the Amerock. However, I've been unable to locate the part. My levers are antique brass and are still functional, but I need the interior one piece replacement part that includes the 2" backset. One side of the lever handset has stationary pins that go through the 1-piece working part to secure it in the hole cut for the door hardware.
the dr
  • 447 Answers
SOURCE: help needed indesit washing machine
well it would help to know brand/model#
Posted on Oct 03, 2007
  • 21 Answers
SOURCE: no ice to the door
The motor is behind the ice bin and yes, it can get water on it and freeze up. I actually fixed one a month ago that I had to remove the motor and let it dry at room temp for a week in order to get it to work when reinstalled. Two or three days and it would freeze right back up in a little while. This usually happens when you've had a problem with the waterfall into the ice reservoir that a bit pours over the edge or when you've defrosted the freezer or left it open long enough to let ice thaw to some degree. You can pull the ice bin out and twist the motor by hand. If it is stuck it is froze but if it moves it is probably bad. You can close the switch with the door open and check with a volt-meter to see if there is voltage going to it if the motor turns freely. It will have a lot of tension but you can turn by hand.
Posted on May 09, 2009
  • 384 Answers
SOURCE: need replacement security door knobs
You find replacement door knobs at any hardware or home improvement store (ACE, Lowes, Home Depot, etc.)
Posted on Jun 11, 2009
smartr10U
  • 1305 Answers
SOURCE: Too long backset on new Door Knob for older home's door
You can get a variety of backsets at a GOOD door/ window company.
You may also want to look closely at the lock bolt again, because some of them come with a backset adjuster. Some of the Schlage and Kwiksets will allow you to twist the barrel and change the backset...
Posted on Jun 19, 2009
  • 115 Answers
SOURCE: I have to replace the 3 1/4 inch porclein levers
check ebay or google them try thhttp://www.shop4classics.com
Posted on Jul 26, 2009
How to remove glass from oven door
didnt specify unit -generic answer --remove door and place on flat surface or floor --un screw the inner panel --remove glass retaining clips [if present ] -replace glass --replace panel and then door done one of the videos in link an assist you
replace oven door glass Yahoo Video Search Results
Oct 17, 2016 | Ovens
How to install new door lock
For a residential door, you may choose either 2 3/4" (70 mm) backset or 2 3/8" (60 mm) backset. Some locks are not adjustable.
Choose the backset required for the lock. Check the thickness of the door. Standard installation height is 35-36" above the floor.
Bore a 1" diameter hole into the edge of the door and a 2 1/8" hole through the face. A drilling jig helps align these two holes. If you measure and mark the holes carefully and drill accurately, it can be done without a jig, but for about $20.00 the jig helps avoid lock alignment problems or possibly trashing a door. Follow the instructions for the jig and the lock manufacturers instructions.
Jul 09, 2014 | Ace Hardware Ace Door Lock Installation...
Replacing door knob need short backset
There are locks with short backsets, but Kwikset doesn't make them. If your door has such a narrow stile that you cannot put a household duty lock into it, you are probably not interested in security, so anything you can find will do the job. Look online for locks for French windows or patio doors.
If you are interested in security, then check out Adams Rite locks, which are used in narrow stile aluminum storefront doors, but they also make some for wood doors.
If you are replacing a very old lock and your style is big enough for a 2-3/8" backset lock, then do it right and treat it like a new installation. Use a jig that can hold the hole saw in the right place, use a router to cut away trim that will get in the way of the lock, and install a modern lockset.
Nov 13, 2013 | Kwikset Locks & Locksmithing
You can shake front door when locked and the door is loose not tight
It sounds like the distance between the lock in the door and the strike plate in the door frame is barely enough to meet securely. Review the lock installation sheet because it MAY be possible to adjust the "backset" for your lock. You did not mention your brand of lock. For example,
Review Steps 1 & 2 of instructions for the Powerbolt:
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Or watch this excellent installation video for the Schlage BE365, at about1:58 minutes into the video you will see how to adjust the backset:
Go to
http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspx#2
Then click on "Installing your BE365 Keypad Deadbolt" video.
Many brands of lock have a similar backset adjustment, and you may have your set too short.
If yours is all ready set for the 2 3/4" backset, then you need some carpenter skills to close up the door gap.
Sep 28, 2012 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
How to install a door glass for a Chev C10 . I am have problems install the glass at the Drivers door. I need some help. As soon as possible
GM Full-Size Trucks 1980-1987 Repair Guide
REMOVAL & INSTALLATION
(see Figures 1 and 2)
Non-Stationary Door Glass
  1. Lower the door glass completely.
  2. Remove the trim panel from the door.
  3. Remove the ventilator assembly as previously outlined.
  4. Slide the glass forward until the front roller is in line with the notch in the sash channel.
  5. Push window forward and tilt the front portion of window up until rear roller is disengaged.
  6. Put window assembly in normal position (level) and raise straight up and out.
  7. Installation is the reverse of removal.
Fig. 1: Door window and regulator
Fig. 2: Removing the door glass
Manual Door Window Regulator
(see Figure 3)
  1. Raise the glass to the full up position and tape it to the door frame with fabric tape.
  2. Remove the door trim panel.
  3. Remove the regulator to door panel attaching bolts.
  4. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
A notch is provided in the sash panel to allow disengagement of the forward roller on the window regulator.
  1. Collapse and remove the regulator assembly through the access hole in the door.
To install:
  1. Prior to installation, lubricate the motor drive gear and regulator sector teeth.
  2. Collapse the regulator and insert it through the access hole in the door.
  3. Unfold the regulator and engage the forward roller to the sash cannel at sash channel notch.
  4. Slide the regulator rearward to engage the rear roller to the sash channel. Also engage the lower roller to the regulator rail.
  5. Slide the regulator into its proper position, and insert the regulator drive through the door panel.
  6. Attach the regulator to the door.
  7. Install the door trim panel.
Fig. 3: Manual window regulator
Power Window Regulator and Motor
(see Figure 4)
Fig. 4: Power window regulator and motor
  2. Disconnect the negative battery cable.
  3. Remove the door trim panel.
  4. Remove the remote control bolts and lay the control aside for access.
  5. Remove the regulator to door panel attaching bolts.
  6. Disconnect the harness from the regulator.
  7. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
  1. Remove the regulator assembly through the access hole in the door.
CAUTION Step 9 must be performed when the regulator is removed from the door. The regulator lift arms are under tension from the counterbalance spring and can cause serious injury if the motor is removed without locking the sector gear in position.
  1. Drill a hole through the regulator sector gear and back plate. DO NOT drill a hole closer than 1 /2 inch; to the edge of the sector gear or back plate. Install a pan head sheet metal tapping screw (No. 10-12× 3 /4 inch;) in the drilled hole to lock the sector gear in position.
  2. Remove the motor to regulator attaching screws and remove the motor from the regulator.
To install:
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the retaining screws.
  3. Remove the screw locking the sector gear in the fixed position.
  4. Reposition the motor in the door and install the wiring connector.
  5. Attach the regulator to the door.
I really hope help you with this (remember rated this help) Good luck.
Oct 06, 2009 | 1980 Chevrolet Corvette
Need to replace broke window on 93 ford tempo.Pass. side
Door Glass, Front Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05. ani_caut.gif CAUTION: Prior to removing center pins from the rivet, it is recommended that a suitable block support be inserted between door outer panel and glass bracket to stabilize glass during rivet removal. Remove center pin from each rivet with a drift punch. Using a 1/4-inch diameter drill, drill out remaining rivets as damage to plastic glass retainer and spacer could result.
  1. Remove two rivets attaching glass to run and bracket assembly.
  1. Remove glass.
  1. Remove drillings and pins from bottom of door.
Installation
  1. Snap plastic retainer and spacer into two glass retainer holes. Make certain that metal washer in the retainer assembly is on outboard side of glass.
  1. Insert glass into door.
  1. Position glass to glass bracket. Install two rivets to secure glass to glass bracket. NOTE: Two 1/4-inch-20 x 1-inch bolts and two 1/4-inch-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (36-61 lb-in). Equivalent metric retainers (6mm) may be used.
  1. Install door trim panel and watershield. Refer to Section 01-05.
2-Door Vehicles
4-Door Vehicles
May 29, 2009 | 1993 Ford Tempo
Apr 15, 2009 | Hardware & Accessories
I need to replace the passenger side front window on a 1980 cadillac fleetwood. How do I remove the door panel correctly? Where do I go from there?
You need to remove all screws first. Any screw visible. Remove the chrome cup from the door handle area, the door strap, and the master control switches. Can't remember if there are screws on the lower end of the door panel or if there is plastic clips. If there are plastic clips, go to an auto parts store and get the tool for it. It looks like the tool you use to remove dandelions...flat tip with a slot in it. Slip it between the door panel and the door itself and pop the panel out. Try and get behind the clips. Once you have it unscrewed and unclipped, pop the panel upwards....you might have to jiggle it a little to get the seal off of the glass.
Once you have the panel off, just take a look at the glass and the channel it is sitting in. It is pretty straight forward.
Mar 16, 2009 | 1980 Cadillac Deville
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Hardware & Accessories Logo
174 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
