posted by myersonrich on Feb 23, 2007
The menu for my DVR has been really slow. The Playing List is the slowest.
I have unplugged the receiver to reset it and that did not work.
I have tried all 4 of the resets programmed into the machine and that did not work.
I have turned off the automatic record from the suggestion list.
Any suggestions would be appreciated.
Best Solution
posted on Mar 02, 2007
For all intents and purposes, your receiver is identical to the Direct TV R-10 (which is also made by RCA). There are TWO POSSIBLE SCENARIOS AND TWO POSSIBLE SOLUTIONS. PLEASE READ BOTH FIRST:
Scenario #1 (Applies to 90% of situations) If this is a software issue: There are a number of software issues related to this receiver that Direct TV software engineers have been working on. If the receiver worked well before and then started running slowly unexpectedly, I would lean toward thinking that DirecTV downloaded a software patch that didn't take on your receiver. I would pull up the systems information screen and copy down all information especially the software version number and call DTV technical support to find out if you have the correct software version for your particular machine. There are a few minor difference between yours and an R-10 (like Hard Drive size and memory)which, in a rare case, might cause this problem. TiVo's use the Linux Operating System. A wrong kernel version, or software module can bog everything down. Be aware also, if they cannot fix it by resending and reauthorizing your receiver, the next step would be to do a hard restart. This is the setting in the menu "erase everything" which reformats (re-initializes the drive) You will receive a screen message which says this could take up to an hour (in some rare cases 2) The hard restart/reinitialing will erase all of your recordings and settings. If this doesn't fix the "slow" problem,(you will be able to tell after 3 or 4 days of use) Direct TV will offer to send you a replacement R-10 (which is also TiVo; you pay only the shipping of $19.95 and in some cases they waive that.
Scenario #2 (Applies to 10% of situations) Hardware issue. If it can be validated that the correct software version is installed and all systems settings have been reset, reauthorized, and tried without positive results, then this may apply: DVR's save and store programs on a computer Hard Disk Drive. It is possible that slow reaction and response from your DVR is also an early warning sign of a Hard Drive that is beginning to fail and encountering errors and slow data storage (your shows and movies) and recovery. If this is the case, then a new replacement hard drive would be in order (only if you own the receiver and it is not leased) It is easiest to order replacement hard drives off the internet. You can't replace them with just any drive, however. The drive needs to have the Linux OS with the TiVo software kernel installed first and pre-initialized. You can have a professional do it for you or if you are electronically inclined, you can replace the hard drive yourself. Replacement drives normally have instructions included giving you step by step procedures for removing the old and installing the new drive. I order TiVo drives from www.weaknees.com. They are a known and reputable supplier of pre configured Maxtor Hard Drives which are specially designed for Home DVR's (I only recommend Maxtor or Seagate brand Hard Drives and these Maxtors are of special high quality). You may have to get an upgrade to an 70 hour (80GB)drive since your 40GB (35 hour) is harder to find and quite possibly no longer in production or available. If you want, you can send your receiver to weaknees and they can professionally install and configure everything for you. (Weaknees is located in Los Angeles, Ca) I have no interest in them, but I am satisfied that they know what they are doing. I hope this information helps you.
Good Luck and best regards,
Eric,
Eric,
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA DVR-40 DirecTV DTV Receiver /
Email this problem
Email this problem
Can you Help with these TV Receivers and DVRs problems?
Phillips 60 inch projection TV...
I know the TV is HD ready, so... Answer This...
Celestial HD Digital Television...
I have just bought one of the... Answer This...
RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
RCA Direct TV DVR 40gb ...
On my above model dvr, one... Answer This...
Repair Service
Find TV Receiver and. Repairman Near You:
Find Parts
