Question about Sewing Machines
Problems threading a Europro serger
I was sewing just fine until a needle broke. I have rethreaded my machine many times (spent 5 hours!) with no good results. The serger will not form loops. Nothing else looks to be wrong.Can you please advise and thank you in advance!
  • 202 Answers
Probably the needle hit one of the loopers and left a burr on it that is catching the thread. Run your finger nail acroos the edges of the loopers. If you find a burr it can be polished off using very, very fine crocus paper from a hardware store.
Or the needle hit a the upper looper and knocked it slightly out of position.
After you have it threaded (correctly) turn it slow by hand and watch the loopers very closely. You will probably see what is happening.
Posted on Dec 12, 2008
I have an elna 664 serger and I am experiencing skipped stitching. I am sewing thicker fabric, so I am assuming this might be the problem, but not sure. I was told it might be my timing but I am not sure...
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. Possible timing problem--need to be checked at a sewing machine shop
May 01, 2014 | Sewing Machines
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding off the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Aug 21, 2013 | Singer 14SH654
Kenmore serger thread keeps breaking
7. Is the thread feeding of the cone/spool freely?
Mar 26, 2013 | Sewing Machines
My needle broke on my serger and i replaced it and now wont make stitch. please help
some times when you break a needle in a sewing machine or
serger it can cause the machine to jump time, it would be a good
idea to have the machine checked for a timing problem or to see
if when the needle broke it caused a problem with another part in
the serger.
Nov 12, 2012 | Sewing Machines
White Superlock serger continually breaking needles
First take all the thread out of the machine. Put in new needles and run the machine slowly by hand and see if there is a problem with timing. If the needle hits and bends or breaks... take it in to be timed. If the needle don't hit....
Make sure you are properly threading this thing. Unlike a sewing machine which gives you some leeway, Sergers must be threaded in a certain order. Typically, upper looper, lower looper, right needle left needle. If you break a thread you can't just rethread that thread... you have to start from the beginning.
You might check singerco.com for the manual for this thing. They have most of white's manuals online they are identified by a W before the serger model number.
Oct 04, 2012 | White Sewing Superlock 1934D Mechanical...
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Husqvarna 910 won't create a chain.
You may have knocked the machine out of time if the machine does not pick up stitches.
Jan 21, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
122 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
