Question about Toshiba Satellite A105 Notebook
Toshiba model number psaa8u-02000u hard drive removal
I need to safely remove the hard drive and then reinstall it. I have an infected drive and wish to remove it, install to a portable usb drive holder, and then plug it into a protected system and run virus scan on the drive. Any advise would be appreciated. I would then need to reinstall the drive and get my wireless connection to the Internet back.
    Scholar:
  • 37 Answers
Why not just go to safe mode with networking support then scan the drive with housecall over at http://housecall.trendmicro.com/ or one of the many other free online virus scanners.
Seems to me it would be easier than removing the drive.  ut if your dead set on removing the drive usually if you look at the machine there will be a pannel on the front about an inch wider than the drive itslf.  flip the computer over and there should be one screw in the middle of that pannel or paossibly one on each end.
Unscrew them and the drive should slide right out. If you take them out and it still is stuck in there then pull the pannel out a bit and look inside for an extra screw, but most of the time its just the one.
When putting it back in make sure you have it back in the hard drive enclosure correctly and the addapter on if it was on it when you pulled it out, then just slide it back in and put screws in.
hope this helps.
Posted on Dec 08, 2008
How do i unlock my bios password on a blue screen i forgot it
disconnect the cmos battery or reset it with the jumper
Sep 23, 2015 | Toshiba Satellite A105 Notebook
Help my laptop isn't working
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 06, 2013 | Computers & Internet
I Cant get my toshiba satellite L305D-S5974 to load. I get either a blank screen with curser arrow or message that says: no bootable device -- insert booth disk and press any key. Can't find any of my...
The laptop is not seeing any hard drive. remove the panel underneath (2 screws) and remove and refit the hard drive. If it still does not work then enter the bios by hitting the F2 key while booting and look at that page. under HDD model name and hdd serial number there should be information on the drive. If there is such info then the drive is being seen but cannot be accessed. Anyway it looks like the drive has had it. You will need to find your windows disk when you fit a new drive and reinstall windows.
Apr 27, 2011 | Toshiba Satellite L305D-S5974 Laptop
ON my Toshiba Satellite M-45 S355 I got a blue screen with a message; STOP: c000021a (Fatal System Error) The session manager initialization system process terminated unexpectedely with a status of...
do not believe you need replace the hard drive
i think you may have a registry error
you may have a application conflict or surface error
try booting in either step mode or safe mode
step mode will let you know where in the boot process the error occures
in safe mode you can run a registry utility like iolo system / registry mechanic
& run error checking
if you need neer to remove & backup your drive you can get a hard drive usb adapter cable set $10-$20 - less work
Nov 04, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
Model number for the interior cooling fan, for a toshiba laptop
I have found a link to a web site that sells them but they are dear they have the product code also for your fan so you might get one cheaper on ebay or something.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&cPath=66_140&products_id=1250
Feb 25, 2010 | Toshiba Satellite A105-S4074 Notebook
I have a toshiba psaa8u-1l502k and i need to reboot the OS, i have no disc, looking for a function shortcut key or something.. thanks
I don't know if your machine supports HDD recovery from a hidden partition but this how you perform it without recovery CD's.
Make sure the computer is turned off.
Hold down the 0 (zero) key while powering up the laptop. When the computer powers up the Toshiba Recovery Wizard should appear.
Just follow the on-screen instructions to factory or out of the box restore.
Regards.
Sep 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
I need the driver of Toshiba satellite L40,model no PSL48L-02000U
well....... just install xp, delet old partition with vista then goto vista dsk and reinstall drivers or the cpu will be unstable pay attention!!!!!!!! after you do this step MAKE SURE YOUR ONLINE OR HAVE ACCESS. do not install programs until xp is stable. the way to get stable is buy, download sys32 or 64 if you see x86 this is the best app and or sys config that will allow stabilty between to o.s. in FACT! i just done the oppisite of what your doing. so know i do for all and any o.s. whether laptop or desk top! did you vista has the xp features and apps in it? however you have to comb the whole system. if you can get me your proccesser speed and name i can give you some more facts.
Mar 15, 2009 | Computers & Internet
Toshiba M115-3094 start up problems
Okay it sounds like you need to reinstall windows. However, doing so will erase everything on your hard drive. So we need to get that data off your hard drive. You can do this either by purchasing an internal hard drive to usb cable and hooking it up to another computer or by booting with a bootable linux distro, connecting a flash drive and copying the info over that way. Once you have the data safe, you can try booting from your XP disc and try the repair option; this will remove the windows files and leave your data in tact but you should really back it up first.
Also you may want to run a chkdsk on the drive; that may help solve the problem.
Jun 13, 2008 | Toshiba Computers & Internet
HITACHI HARD DRIVE LOCKED
Hello Oldnovii
This Toshiba notebook has both a BIOS and hard drive lock on it. The client has already paid $ 25 to the Toshiba depot to have the BIOS lock removed now they want $ 100 to remove the hard drive lock. The hard drive lock cannot be removed by trying to bypass it using a boot cd or disabling the hard drive boot option in the BIOS. Any help will be appreciated since my client has now had the notebook for 2 weeks and cannot use it. Thanks
Apr 07, 2008 | Computers & Internet
Removing the hdd in my toshiba 1135-s125
OK, This is a big undertaking if you are completely new.
1st, if you can get a static guard wrist band - great!
2nd You will be dealing with plenty of screws so keep track
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
I have .a Toshiba Satellite 1135-S155. It should be a similar configuration, same family/1135-S1xx series.
You will have to remove a total of 9 Phillips screws.
Place the underside of the PC up.
Disconnect all power, cables and Battery from Laptop
The first screw is located just under the Toshiba Serial Number / Bar codes, just above where the DVD/CD-ROM combo drive is located.
Mine is labeled (F5). Unscrew it and place in a safe place.
Pull DVD/CD-ROM combo drive out it is an assembly.
The Hard Drive is located under the DVD/CD-ROM combo drive.
The Hard Disk Drive (HDD) is enclosed within a caddy containing the remaining eight screws.
There are four screws holding the caddy rails to the Laptop and four screws holding the rails, caddy and Hard Drive as an assembly.
Unscrew and place in a safe place/ container they are small. Disassemble the HDD from caddy assembly; place your HD in the caddy and reassembly.
Here is another Toshiba HDD access that is slightly more
straightforward than my 1135 series
So you get an idea of where a HDD is visually:
Above is a photo of the Battery sliding out
Below is the Hard Drive Removal
I hope this gives you an idea of how to go about it for your
particular Laptop
If you need further assistance, let me know
Feb 21, 2008 | Toshiba Satellite 1135-S125 Notebook
Toshiba Satellite A105 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
