Question about Cameras
Thomson digital camcorder vmd 130 mini dv. The strip of ele tape that connects the viewfinder to cam has snaped.Where can i get it repaired.
creeperz
  • 52 Answers
SOURCE: Samsung camcorder
Although my question might sound stupid, but did you charge the battery? The camera should be having a li-ion battery, which does not retain its charge for long(a week or so) which gives the battery a longer life.
If this is not the problem, could you explain the "ticks like a clock" in detail.
I could also be due to the tape getting jammed.
Posted on Mar 19, 2008
ginko
  • 19396 Answers
SOURCE: digital camcorder not charging
You need to test the volts out from the charger with a MultiMeter,
to check if there is power coming out. Your battery may also be faulty, as pointed out from some other expert. In any case the suspect nr.1 remains the adapter.
About the warrantee, you have 12 moths from Samsung , it should be valid even if you register the item right now. Here are details about Samsung 12 months fabrig warrantee in UK. Contact Samsung in your area to get more details.
You are asking help to me and accepted the rubbish solution provided by other expert. Please refuse the other expert solution (unless helpful) accept the right solution in the premium post (the other). Fixya pay the accepted solution only.
Regards
Regards
Posted on Apr 06, 2008
MrsJGreen
  • 130 Answers
SOURCE: software for the canon zr300 mini dv digital camcorder
You will likely have to order this through Canon.
Posted on May 30, 2008
SOURCE: Driver for Sharp VL-Z5 Mini DV Digital Camcorder
Try this
http://www.sharpusa.com/products/TypeSoftware/0,1086,47,00.html
Posted on Jun 28, 2008
SOURCE: Panasonic NV-GS10B mini DV camcorder.
Seems to have been a random fault. Now OK, but for how long? This camcorder has given nothing but trouble. Any further nonesense and it will be destroyed.
Posted on Jul 13, 2008
How do I clean the head when it gives you an alert?
two ways, buy a mini dv cleaning cassette, two if you do not have one, put the cam in play mode, hit play, than fast forward button for a min, the tape going fast sometimes cleans the head. not just fast forward but play, than ff so the tape is hitting the head, other than that, the cam has to be taken apart and the heads cleaned with the proper cleaning solution and PROPER brush as not to hurt the fragile heads
Dave
Sep 15, 2014 | JVC GR-D250 Mini DV Digital Camcorder
No display in viewfinder and LCD
i think you are able too see the video in play back mode. so there is no problem in your LCD.
i think the CCD has got damaged in your CAM. that is why you are not able to view anything in shooting mode.
because CCD is the layer which converts the light falling on it to a electrical signal and shows us as a complete image.
Dec 25, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
My jvc dv mini cam messes up the tape
put cam in for professional service - either the head needs replacing (worn) or the cassette cage is warped and in need of realignment.
Jul 16, 2009 | JVC GR-DF470 Mini DV Digital Camcorder
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Does this cam, play the mini dv tapes????
If you are referring to the JVC GR-DVL520, yes it does play Mini DV tapes, as well as records to them. It will not play Mini DV tapes that were recorded on an HDV camera. HDV is used by any Mini DV camera that records HD video.
Jun 24, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
"wrong format" error panasonic pv gs9
You really need a panasonic camcorder or need a new camcorder that can read your mini dv tape. good luck
May 04, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
Mini Cassette to DVD?
you need a firewire cable to go from cam to computer or use a dvd recorder and put tv connections from cam to dvd recorder
Jul 27, 2008 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Camcorder problem
sounds like the ribbon tape needs to be replaced , or its not connected right , open unit and check for a white tape that connects to the PCboard to the LCD or VIEWFINDER . hope this helps
Apr 28, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Sony DCRHC 42E handy cam LCD problem
problem on ur l.c.d strip (lcd fpc ) u chaing this one
Sep 10, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
How to clean the head of my panasoic gs39
buy a head cleaning tape, you may be able to order them offline, make sure it's mini DV
Apr 05, 2007 | Panasonic PV-GS39 Mini DV Digital...
Cameras Logo
103 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
