Question about Indesit W 123 Front Load Washer
Indesit W123s I hope someone can help. Our washing machine has started making a grinding sound when it starts to spin, sounds a bit like a drill!? During the normal wash part of the cycle it doesn't make this noise. When I stop the program the drum doesn't spin freely like it used to when you push it manually arround. Any help/suggestion would be gratefully received. many thanks in advance.
  • Sellasia Nov 14, 2007
    Indesit WG1030PG the bearing seems to have gone. Are they difficult to change
  • Anonymous Dec 01, 2007
    I have Indiest washing machine model WGD1035T causing a hard noise and the drum is loss, how can I replace the defect part is it the bearing? or some thing else?
    Faray
    Problem Solver:
  • 16 Answers
There is a bearing at the back of the machine that normally goes.don't just replace the bearing.buy a complete bearing kit and replace that.
Posted on Feb 28, 2007
    Problem Solver:
  • 12 Answers
Hi try sales@gwhitedist.co.uk just give them model number and part they come back with a price
Posted on May 04, 2008
    Problem Solver:
  • 6 Answers
Bearing Kits are available from here: http://www.ransomspares.co.uk/indesit-washing-machine-spares.html You need part number 1605077
Fills with water but then does not agitate. Agitator moves only tiny bit in both directions. Pumps out and spins OK but makes grinding sound when finished spinning
I do not work on washing machines, But I had the same problem with my own unit. Replacing the transmission fixed it. I hope this helps you.
Mar 07, 2015 | Washing Machines
I have an Indesit 1400 model WIXL143, washing machine, which is about 3 and a bit years old. It sounds like a tank when its on spin, and makes a grinding noise also. Its also making the washing dirty...
yes probably order them from parts place or eBay but big job to do are you up to it best get quote from indesit probably cheaper new washer
Oct 25, 2017 | Washing Machines
When I turn the drum it sounds like it is rubbing on something between 11&1 oclock on turning cycle indesit w123s
have a tecnician take a look at cause it'' be hard to fix at home.
something between the motor and the drum has loosened which may also cause short-circuit in the future, so just watch out...
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Indesit W 123 Front Load Washer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Hi! I have an Indesit W84TX washing machine. Lately, it has stopped working every time it reaches the rinse cycle. It seems to rinse and drain just one time before the process stops and the settings dial...
Actually, while the settings dial spins, there is also a kind of grinding/clicking sound from down where the drain port is. I checked it and there is no filter there when I open it.
Apr 05, 2009 | Indesit WA 115 Front Load Washer
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine wont spin
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
Tecnik tlk 925 washing machine not spinning
sounds to me like your carbon brushes have worn down if they wear down too far they will hit the metal casing that explains the grinding noise
Aug 08, 2008 | Tecnik TKL9260 Front Load Washer
Indesit W123s - Hates Us
first thing to do is to make sure the washing machine is not siphoning. sometimes if a washing machine is bringing in water its all so draining it ,known in the trade as siphoning. the drain hose must be higher than the tub?? Unplug your washing machine from the wall socket for a minute or two and plug it back in to reset its micro. to me it sounds like a main board fault. I think you might find that it still maybe under warranty. ring a Indesit service agent and get some advice.
Aug 17, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
639 people viewed this question
Top Indesit Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
