Question about HP PhotoSmart 7550 InkJet Printer
Picture crops strange
Sometimes the borders are fine and sometime the border on the print is warped or crooked and I feed the paper in the same way but it will be crooked on the right side and fine on the left...
also can you clean the ink on the bottom..I notice more black ink accumulates there but I cannot get inside with the cartridges removed..I lifted a couple of dried bits with tweezers without touching the cradles..
    Scholar:
  • 93 Answers
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Posted on Dec 15, 2008
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
Uneven borders how do i fix it
If you are trying to do this by setting borders manually you are probably running into the Canon's minefield of "minimal printed borders" which throw off calculations. The manual setting is primarily for off-setting images rather than for perfectly centered images.
For a centered image, the borders are automatically set by the relationship of image sizing to paper size, with "center image" checked and other sizing options unchecked. This has worked perfectly in the three Canon printers I've owned, whereas trying to set even borders manually was always off a bit and a real pain.
If you want the same border width for all sides, the aspect ratio of the paper and image will have to be different, strangely enough, for all but square images. For 1" borders all around on 10x15 paper, e.g., your 2:3 AR image will have to be cropped and sized to 8X13" dimensions.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 07, 2014 | Canon PIXMA Office Equipment & Supplies
Kodak 6850 how do I print 4x6 on 6x8 paper without huge white border... now that you cant buy 4x6 media ?r
the 6'' paper is not the problem at all, you might need to crop the image to 4x6 size before printing since most point and shoot camera will not take the photo 4x6 size but 4+ inches, thus the border. richard
Nov 22, 2010 | Kodak Photo Printer 6850 Thermal
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
No bottom page border
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Apr 04, 2008 | Office Equipment & Supplies
HP PhotoSmart 7550 InkJet Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
