Question about Refrigerators
Kitchen Aid side-by-side (don't know #, but think it's Architect), ice maker not working, water fine. I can't find any solutions on troubleshooting pages. HELP!!!!
    Sergeant:
    Champion:
  • 291 Answers
I bet the module on the icemaker is bad ,,,, if the icemaker set where you can pull off the cover and look at the gear and see if the center pin is broken or twisted then the module is bad and if you contact me i will check on the part for you ,,, if its not then you have a bad valve that supplys water to the icemaker ,,, your frig has a double valve so water in door can work but not icemaker / larry
Posted on Dec 08, 2008
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kitchen Aid side by side ksra2scnss00 ice maker not working....Water dispenser is working fine
The simple solution for your refrigerator is to replace dual water control valve.For example if your model was the IKSCS25INSS the replacement part would be the=> W10247725 Water Inlet Valve It also could be your ice maker itself so if the ice slots ar empty fill with tap water and allow to freeze. If the ice freezes and drops into the ice bucket and then does not refill with water then replace the water control valve. If not then it nis possible the ice maker is defective and will need replaced.Not knowing the correct model number I think it wouls better that you call Repair Clinic at 1-800-269-2609 and they will be happy to help you find the correct ice maker. 2198597 Ice Maker Assembly Should you have any questions I will be here to assist you, Thank You, Sea Breeze
believe you have your model number wrong so I will give you this link=> product literature search
Oct 03, 2011 | KitchenAid Superba Architect KSCS25INSS...
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker not working in Kitchen Aid Superba. Light is blinking constantly on right side wall of freezer. Is this normal?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
44
Sep 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
MY KITCHEN AID KSRP25FNSS ICE MAKER IS NOT WORKING
heatman101
689fr
Jun 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker is frozen in a kitchen aid side by side
Try pouring HOT water into the ice molds to release the frozen cubes. Hopefully the ice maker will restart the cycle and get back to normal!
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
