Question about ViewSonic G810 21" CRT Monitor
Hitachi 19" CRT monitor display twitches and shrinks when hot
I have an Hitachi 19" monitor that has served me well since 1998. But lately, after I'm using my PC for several hours, it will make a slight noise after after which the screen will start shrinking for a second or two, and then it pops back to normal. Though I've degaussed it several times, the problem persists. So, I'm beginning to think my monitor is either overheating or is on its last leg. I was wondering if the 10 years of dust buildup inside the monitor might be the culprit, and I was thinking of taking off the cover and blowing the dust away with a PC duster if it would help. Also, this morning when I moved my mouse to wake up my monitor from power-save mode, it made a moderately loud snapping noise. I thought it had died, but was quite relieved when it didn't.
  • netbids Dec 10, 2008
    Thanks to both of you for posting. I guess it's worth trying the suggestion of resoldering bad joints. I just need to find a local shop here that won't overcharge me. If it solves the problem, I'll keep using because this monitor has not decreased in quality at all that I've noticed. It was the best 19" monitor available at the time. The picture is still sharp, and the colors are still great. If resoldering doesn't work, at least I can say I tried. Thanks again!
  • 3 Answers
I would beg to argue with the lifespan of CRT's. 8 years with decreasing quality after 4? Are you buying Sceptre and Komodo monitors?
CRT's should last 10-15 years. Look at my 21" Compaq P1210 from '95 - still going strong @ 2048x1536x72hz.
It seems the most common advice for problem equipment is to just replace it, but I disagree, especially in this economic climate.
I would be willing to make a bet that your fly-back needs to be replaced.
Find yourself a mom and pop shop that specializes in monitors. Shouldn't cost more than $50.
Posted on Feb 15, 2009
  • 4,234 Answers
Sorry Jamess02, the problem at this point is bad solder connections. The snapping you are hearing are sparks jumping the gap. If this is not fixed soon, there will be permanent damage done that will not be worth the repair. Any shop can fix this ion about 10 minutes. Simply open up the unit and resolder any connections that appear grainy or have rings. Please note that there are dangerous high voltages present even with the unit unplugged that can cause injury.
Posted on Dec 08, 2008
  • 68 Answers
It sounds like it is on it's way out. The lifespan for a CRT Monitor is about 8 years (at most) witha  noticeable decrease in quality at 4-5 years. I have seen them last longer, but not much. I would recommend getting a new 19" LCD which can be purchased right now for under $125 online. (Still 200 at Retail store) Opening it up to clean it out is not advised. (the dust could be the only thing keeping it alive) JK
Good Luck!
HP 7540 crt monitor shrinks to a horizontal line
It would be more economical to purchase a new or used LED/LCD display rather than wasting money on an old CRT monitor.
Feb 22, 2012 | HP COMPAQ 7540 CRT Monitor
The display is shrinked vertcally in the centre of my LG 915 monitor. plz help me out. Thanks
Hi nasirallahdi ,
If your display is shrinked vertically , please follow the below steps :-
  1. Check the settings button on your monitor , when you press the button you have multiple options coming up which includes reset option.
  2. Go to the reset option and select ok , so that your monitor is reset.
  3. If this does not solve your problem then it could be because of a incorrect resolution being set in your desktop properties , in the settings tab.
  4. To change the resolution settings you need to go to the display settings by finding the option on the desktop via right click and you can try changing the resolution and see if things get ok.
  5. If still the problem persists , then it could be a hardware fault which you need to get repaired via the manufacturer's warranty limit , if it has expired you will be charged for it.
  6. Most probably the problem is with the incorrect settings in the monitor panel , and i believe after you reset your monitor via the monitor panel , things would be alright hopefully.
Hope this helps ...:)
May 10, 2011 | LG Flatron 915FT 19" CRT Monitor
Mag Innovation LT916s 900p LCD with a Horizontal twitch
That is capacitors problem, I would change all the caps in the 5v and 12v power supply section, you can have bad caps with high ESR. Also look at the caps on the logic board. I use hair dryer for troubleshooting to locate bad caps.
Apr 15, 2010 | Mag Innovision 19" LCD Flat-Panel Monitor...
Hi there, i have a samsung t190 and it keeps twitching!
Try to check connectors including ribbon wire and try to trace some possible lose connection especially for with add on ckt. Try also to re-solder pins on hot area.
Mar 21, 2010 | Samsung T190 19" Widescreen LCD Monitor
LG Flatron EZ T530S
Check your connector to your computer if that's good check the HOT if it's bad replace the HOT and flyback. Check the SMPS caps.
May 23, 2009 | LG Flatron Ez T910B 19" CRT Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
LaCie 10 CRT
I would try booting the computer in safe mode (if it's windows) and adjust your display settings. It sounds as though it is trying to display from your computer something that it cannot properly.
Mar 28, 2007 | LaCie Electron IV 19" CRT Monitor
Monitor display is totally moved to the left.
Start >> Control Panel >> Display >> Settings >> Advanced >> Intel(R) Extreme Graphics 2 >> Graphics Properties >> Hot Keys >> Check mark on Enable Hot Keys >> APPLY.
Now press ALT + CTRL + up (ARROW).
Make sure after doing this uncheck on Enable Hot Keys.
Feb 18, 2007 | HP Compaq S9500 19" CRT Monitor
Screen flickers
The problem is that it is on the verge of going out my mother had a monitor go out and it did the same thing. Also if you have any high frequeny things around your monitor thatr also migh be the thing. Try a magnet or demagnitze the screen if you have one on it.
Dec 04, 2006 | ViewSonic G810 21" CRT Monitor
ViewSonic G810 21" CRT Monitor Logo
498 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
