Question about Sony Xplod XM-1652Z Car Audio Amplifier
HOW DO I BRIDGE MY DUAL VOICE 4OM TO 2OM
THANKS
    Sergeant:
  • 300 Answers
Tie both "+" terminals together and then both "-" terminals together. That puts the voice coils in parallel, making the combination a total of 2 ohms.
Posted on Dec 08, 2008
How do I bridge a sub 12 Kenwood kfc-w3003
old school huh? Well those Kenwood subs are single voice coil so you can't bridge them to themselves like you can do with dual voice coil models. however, if you have two or more the speakers can be bridged to each other. You can wire them either in series or parallel. If you need instructions on how to do this just Google wiring two single voice coil subwoofers/speakers. There are plenty of detailed illustrations available on the web.
Aug 31, 2015 | Kenwood Car Audio & Video
I need help hooking my kicker cvr 12 to my direct 600 amp
Is the sub a single voice coil or dual???? If its a single, just bridge sub to amp....(+ of one channel and the - of the other) amp should show where to bridge with a diagram near speaker outs. If its a dual voice coil, then run one voice coil to the left channel and one voice coil to the right.
Nov 02, 2010 | Directed 600D Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Wiring dual voice coil speakers
need to bridge 15" dual voice coil speaker
Jul 10, 2008 | Audio Players & Recorders
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
Prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
Mar 15, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Subs
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Feb 25, 2008 | Car Audio & Video
Amp Problems
You are probably presenting too low an impedance load to the amplifier. In bridged mode the amp must be connected to a minimum 4-ohm load. If your subwoofer is a dual voice coil type with 4-ohm voice coils, you cannot wire the voice coils in parallel and connect it to the bridged amplifier. If you have a sub with dual 2-ohm voice coils, you can wire the voice coils in series and connect it to the amplifier in bridged mode. To connect voice coils in series: Connect a wire from the negative terminal of one coil to the positive terminal on the other coil. Connect the unused positive and negative terminals to the amplifier's output.
Mar 14, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
