Question about Polaroid FDM0700A Under the Counter 7 LCD TV with DVD Player Television
IC2 I found that IC2 for the back light is bad. I can not find a part number for cross refernce, any ideas?
  • jim k May 11, 2008
    I have sound but the screen is black.
    Problem Solver:
  • 3 Answers
It is a known defect that polaroid won't stand behind!  The original part which I suggest not to but b/c it will just burn up again is UI8007S-1...I highly suggest buying an upgraded part from www.lcdparts.net which is UI8007S-1MSS, and actually less expensive than the worthless original.
I will never purchase a Polaroid product again!!!!
http://www.mp3car.com/vbulletin/lcd-display/74566-backlight-inverter.html
Posted on Jan 20, 2008
SOURCE:
CROSS REFERNCE NGK 25594 O2 SENSOR
http://www.oxygensensor-crossreference.com/convert/denso/234-4173
Mar 11, 2015 | Cars & Trucks
Who is the manufacturer of the dc470a motherboard? I recently found a HP Pavilion 505n desktop would i be able to but a Intel Pentium 4 3.2GHz 800MHz 512KB Socket 478 CPU into it ? thank you for your...
The HP Pavilion 505n desktop has a 845GL series board in it, with a : Intel Celeron 2.2GHz
  • 400MHz Front side bus
  • Socket mPGA478
You need to look at the actual board model number is and cross refernce it on the list of boards, listed to the right od the 845 column on this link: http://www.intel.com/support/motherboards/desktop/sb/CS-023522.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2011 | HP Pavilion 505n (DC470A#ABA) PC Desktop
I have a ic2 pump on my pressure washer, the diagrams have failed. My question is I need the parts to repair it, or how to purchase a replacement.
You can purchase a complete unit from Grainger for about $210.00. Their part number is 6UZP8. And in most cases they are located locally, so you can pick it up and be back in business quick. The pump is actually manufactured by Excell Power, so my thought would be replace the pump and then try to find a rebuild kit for the bad pump and try to rebuild it as a backup. Hope this helps.
http://www.grainger.com/Grainger/EXCELL-Assembly-Pump-6UZP8
Jun 13, 2011 | Honda Garden
Hi, I own a hp laptop and at times, while using it the screen freezes and you wont be able to move the cursor nor click on anyting on the screen. It will only start working after you swicth off and...
most likely a overheating problem. even though you havent stated your laptop model number
cross refernce it with hp website and they might be offering extended warrnty on your mode of laptop
Oct 16, 2010 | Computers & Internet
98 VW Volkswagen GL, Dash lights out, not a bad fuse, dimmer, or light switch. Lights come back on periodically, but when I hit a bump, or if knock on the dash with my fist, they turn back off..What's...
The last time I fixed a problem like this it was a bad connection on the back of the instrument cluster. I found it by working in my garage in the dark. I removed the cluster and wiggled wires with the lights turned on, until I found the trouble spot. I then took a pencil eraser to connections in the area, then cleaned it with alcohol. Put it back together and all was well again. best of luck!
Jan 31, 2010 | 1995 Volkswagen Golf
Picture is smaller, has hourglass shape, no sound
Took back off, removed control board and inspected for bad solder joints. found no obvious problem. Cleaned and reinstalled. Working ok now. I'm crossing my fingers.
Jan 27, 2009 | Philips Magnavox TS3260C 32" TV
My Plaxma flat screen, AKAI PDP4294 is dead
Well, I will tell you Jim that plasma flat screens as a whole are having similar problems without regard to brand or model. Part of this problem with others has been the poor quiet fan cooling setup they have in them to say the least. The problem you have experienced is in the voltage regulator section of your power supply. Without being able to see exactly the section the IC2 is in I would have to look at a good schematic to find the right part # for. However, through my experience oveer the years I usually go ahead and desolder the part and take it to a large electronic supply house and they are usually more often than not able to identify the component for you without a schematic. However as you said and you are correct in thinking that the plasma tv you have may give you a similar problem in the future without any added cooling fans on the back cover. Do not be deceived though because LCDs over 32" and above suffer similar problems with the added one that they have images that actually burn-in to the screen much like computer monitors and that is annoying as well. Even if your tv is more than 2 years old and past the warranty period, you may be successful in getting it replaced with a new one because you have a very common problem occuring here that I know the manufacturer knows about. Most plasmas are rate to have 60,000 hours of use which is 20 years, they just have not developed or been around long enough to substantiate that claim. Good luck and God bless.
Jan 14, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Compatible replacement
GE Customer Service is here. They can tell you if they have a comparable "drop-in" replacement.
You can usually find helpful exploded view diagrams and order parts & accessories by entering your full model number here.
Nov 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cobra 18 WX ST Wont Transmit
Hi rem_fishing ,
Would seem that your Audio IC is busted. No receive audio, no TX audio. This would be IC2, KIA7217AP
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 29, 2008 | Radio Communications
Polaroid FDM0700A Under the Counter 7 LCD TV with DVD Player Television Logo
408 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
