On start up goes in a continuous restart cycle
Emachine w 3107.Did F8 on boot deactivated the reboot capable, show error msg as follows, problem detected windows has been shut down to prevent damage to your computer. unmountable_boot_volume. I don't have the recovery discs, Emachine's website states that recovery can be done from hard disk as well unable to locate recovery data on hard disk. Any advised would be appreciated.
    Scholar:
  • 68 Answers
There is usually a hot key you can press during boot up to start recovery (F11 is typical) This will guide you through the recovery process. I would first check all of your cables going to your hard drive, and also the one going from the hard drive to the motherboard. See if that helps. Best of luck to you!
Posted on Dec 08, 2008
Can't find my startup disc for my emachine, is
yes windows xp potable CD will solve it but select boot from CD ROM rather boot from floppy disk or you can use windows xp on bootable flash memory or you can restore your windows it might work
May 23, 2011 | E-Machines eMachines Desktop PC
My computer msi brand is automatically restarting and some problem are appear but i cant read becouse it is continusly restarting...i rem the time when im not in my mood and keep badtrip to my computer so...
You have two options to remedy the problem. You really need to access the computer in Safe Mode and view the System Logs to determine the offending piece of hardware or software or virus. But your real question is how to stop the reboot. Use the F8 Key during boot. Right after you turn the computer on, start hitting the F8 Key. The Windows Boot MEnu will appear. at this point you can do one of two things to try to fix the problem. You can enter the computer in Safe Mode which load Windows with only the minimal necessary hardware and software drivers.If you want to see the error message, choose option 8 which tells the computer not to automatically restart after an error. This will enable you to determine the error message on the screen and prevent the system from just going through an endless loop of starting, erroring-out and restarting..
F8 (during boot) Holding F8 when booting displays the Windows Boot Menu
SHIFT (during boot) Holding SHIFT down when booting forces Windows into Safe Mode
Let me know if I can be of any other assistance to you
May 15, 2011 | Microsoft Windows 7 Professional for PC
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
My Emachine T5010 reboots on Windows loading screen.
Before windows loads press F8 on the keyboard to get an advanced menu.
choose the option that says disable automatic restart on error and see what error you get.
Also try the Safe Mode option.
That click sounds like the harddrive is failing.
Nov 02, 2009 | E-Machines T5010 PC Desktop
I need to know the reboot menu on the t1090 thamks
What OS is installed?
A lot of Windows machines will let you into the boot menu by tapping F12 continuously when you restart the unit.
Tapping F8 accomplishes the same thing on some machines.
Check this thread as well, it may assist:
http://www.computing.net/answers/windows-xp/emachine-t1090/169935.html
Your description of the problem isn't very specific- ie: Do you get a specific error message when booting the machine?
Oct 07, 2009 | E-Machines T1090 PC Desktop
Laptop stuck on Startup Repair & restart cycle
Press F8 while it boots up, and start it in safe mode. Then disable the Automatic Restart on system failure. When it reboots, you may get a blue screen stop error code of some other error message and it may continue to fail to start. If so, make a note of the exact error message and report back...
See articles about this procedure here, here, and here.
You could also reboot into safe mode and use System Restore to restore it to an earlier state that worked.
And you should probably take a look in the Event Viewer and see what kind of errors or warnings are reported in the applications tab.
Is it possible that this condition is malware related? If so, please follow these protocols. At least perform the first 4 steps to scan your system for problems and make sure it's updated.
Here's a more general troubleshooting guide for startups, and here's a wealth of info from HP specific to your model that may help you to figure it out.
Good luck with it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 12, 2009 | HP Pavilion dv6000z Notebook
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
Hello,l'm trying to formate my daewoo pc.l press Delete to inter setup,however, it is on safe mode.l want to start the setup from the CD.Thing that l'm finding it hard now.so, please,can you help me find...
REBOOT..GO INTO THE BIOS AND MAKE YOUR CD/DVD FIRST BOOT RESTART.COMPUTER WILL BOOT FROM CD.FOLLOW THE PROMPTS AND FORMAT AND REINSTALL..THEN ACTIVATE.RICHARDM69
Dec 03, 2008 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
