Question about Sony VAIO VGC-RB42G PC Desktop
How to hook my sony VAIO to TV via HDMI
I have a HDMI cable and HDMI ports on both my tv and laptop when i hook it up i just get a blank screen??? Do i have to change my settings?
  • 1 more comment
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    check the display settings on the laptop..restart the laptop with the connection..
  • Anonymous Mar 29, 2014
    hdmi port not on sony vaio
    is there a hdmi port on sony vaio
  • 1,498 Answers
Hi there Dream,
There is a toggle function for switching the display. It cycles from normal to external to both.
You are looking for one of the F-Keys (Normally F5) should have a little rectangle between two vertical lines. It's supposed to be a monitor.
To cycle the display, press the Fn key (near the space bar), then the F-key. Your standard display should go blank. To get it back, do the same thing.
If your TV still displays nothing, Check which input its using.
This should get you going.
Mike
Posted on Dec 08, 2008
  • John Jan 24, 2011
    I have to make sure that my TV is set to the proper AVI setting as well. I have my computer monitor set to AVI-4 You may want to check that out as well. John
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Oct 26, 2012 | Fujitsu Computers & Internet
How to activate my laptop to my samsung tv
If you mean watch what you see on your laptop on your TV, then you need to connect an HDMI cable or S-Video cable (depending on what sort of ports you have) from your laptop to your TV, then select the appropriate input on your TV or TV remote. For example if connected via HDMI and your TV has 2 HDMI inputs (ie. HDMI 1 and HDMI 2), select which one you connected to.
Jan 26, 2012 | Sony VAIO Notebook
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I have my laptop hooked up to my Sony LCDTV (using it as a big screen) via HDMI cable, but now the laptop screen doesn't work. I disconnected the HDMI cable and restarted the laptop but the screen comes up...
Go into your display driver, and make certain you have it set to have the internal LCD as your primary display. There should be an option to go ahead and have it either act as a second display just cloning what's on your screen or to have it extend. (select the option to clone)
Oct 03, 2010 | LG LW20-EV Notebook
How do i connect my sony vaio to my Technika 42'' hdtv?
does your Technika 42" hdtv have a RGB connection, it will look like the same type of video connector on your computer, also if your sony vaio has a HDMI connection and your tv does as well, you might try hooking them up via an HDMI cable.
Nov 18, 2009 | Office Equipment & Supplies
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Blank screen on HDMI connection
I have good new and bad news The good news first: believe it or not you have solved the problem and the HDMI port on you TV is not working. Now for the bad news: What ever damaged the HDMI port on your TV also damaged the DVR UNIT, and it looks like it could be in the switching section. What that is is the point where viedo is delivered to the various ports by the DVR Unit, I should call it more of a crossover point,since the signal is processed differently by the various output ports. I would suggest that you get the HGMI port in yoyr TV repaired and the DVR repaired at a qualified shop. There are no repairs that you can affect on these devices.
Sep 07, 2007 | Directv HR10-250 DTV Receiver
Sony VAIO VGC-RB42G PC Desktop Logo
5,546 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
