Question about Motorola Talkabout Distance DPS (10 Channels) 2-Way Radio
New pair of new motorola talkabout distance dps radios.
1 of the radios. when message is finished coming in, the radio instead of going quiet is solid static, like a CB with squelch turned up all the way. The only way i can silence it is to change channels. Any fixes.
  • 27 Answers
Can you check the PL or DPL setting on the radio that is all stadic when you receive a call?
The radio is going into monitor mode after a call is received. This is most often a PL or DPL issue.
Posted on Dec 10, 2008
Is there any replacement for the rubber outer housing on my Motorola T6510 radios?
Replacement parts were never made available for the TalkAbout radios (other than the higher wattage TalkAbout Distance and Distance DPS). Your options are replace the radios, or watch for used radios for parts on ebay and other similar websites.
Best regards.
Jul 20, 2014 | Motorola T6510 XLR Talkabout Two-Way...
Tip
TalkAbout Distance Charging & Battery Options
The Motorola TalkAbout Distance and Distance DPS radios have a rechargeable NiCd battery pack (HNN9056 and/or HNN9044). Use of this battery pack is the best method for powering the radio. This type of battery pack has a 18-24 month life expectancy. You can determine the age of your battery from the date code on the back of the battery above the stop sign. The first digit is the year and the next two are the week of the year. Ex: 919 would read 2009 the 19th week.
The DPS model came with both a NiCd battery tray and an Alkaline battery tray. While the NiCd battery pack is the best option for fully powering your radio, along with being the most economical option, in a pinch or when charging is not available the 6 Alkaline batteries will power the radio for up to 18 hours. Note: Replacement battery trays are no longer available, it is advisable to keep both trays. If one fails, you will have the other as a backup.
The TalkAbout Distance is a repairable radio. The consumer replaceable parts are the NiCd battery pack, belt clip, antenna and charger.
on May 06, 2009 | Motorola Talkabout Distance DPS (10...
Motorola Talk About distance dps battery tray bad. Where might i locate another b tray. THANKS! MODEL P24SRY03G2AA
Unfortunately replacement battery trays (both alkaline and rechargeable NiCd type) for the TalkABout Distance and Distance DPS have not been available for several years. We have had some success in repairing existing trays, here in the repair shop, if the damage is not too severe. As for a source, you might watch ebay for another unit for parts, or replacing your existing radio. Be certain to quiz the seller on the condition of the battery tray.
Best regards.
Nov 05, 2010 | Motorola Talkabout Distance (10 Channels)...
Need battery tray for motorola dps radio
[This is not a solution, but a commentary on the need for a tray. Please do not rate this post, as it is meant for informational purposes only.]
This is more common that you might think. The battery trays (both 6-AA Alkaline and NiCd rechargeable-style) have not been available for a few years from Motorola. From a nationwide repair center perspective, we find some damaged trays can be repaired, and some owners find a "parts radio" from sources such as ebay.
For those of you reading this posting which have the TalkAbout Distance or Distance DPS, let this please be a reminder to take care of your trays. Once the tray is gone, the radio is not functional, nor can it be repaired.
Best wishes on your search and please post back if you do find one.
Best regards.
Aug 13, 2010 | Motorola Talkabout Distance DPS (10...
I need to know the watt of the t5509
The TalkAbout radios are 1/2 watt radios, with exception of the older larger TalkAbout Distance and Distance DPS, which were 1-2 watts.
Best regards.
Apr 12, 2010 | Motorola Talkabout T5500 (7 Channels)...
Hello I am wondering if I can get a bigger anttana for my distance DPS or if there is a way to increase the wattage on them please help Dave
1efe_2.jpg Please wait Image not available I used this antenna, from ebay. It's twice the length. I bought a pair of these:spacer.gif UHF Antenna for Motorola HT1000 MTS2000 MTX8000 095A
I tested it last weekend in Vermont, 1.72 miles, 60 feet elevation differential, through woods. First unit inside a wood frame dweling. Second unit was inside a steel frame building, wood sheathed. Communications was faultlessly clear.
Feb 23, 2010 | Motorola Talkabout Distance DPS (10...
Motorola talkabout distance dps
You can change the squelch setting with the user buttons, You could set a PL or DPL but the other radio's that you talk to will need the same setting.
Go here for the manual:
http://pdf.textfiles.com/manuals/SCANNERS-F-R/Motorola_Distance%20UHF%20Porto_Manual.pdf
Dec 08, 2008 | Motorola Talkabout Distance DPS (10...
MOTOROLA TALKABOUT T5400
First check your batteries. Try the battery pack from a known good radio. If you do not have a battery problem, your issue is probably non-reversible. Sorry. This style radio is non-repairable. The repairable Talkabout units include the Distance, Distance DPS, the TA-7400 and TA-7200.
Jul 11, 2008 | Motorola Talkabout T5400 (14 Channels)...
Motorola Talkabout Distance DPS (10 Channels) 2-Way Radio Logo
166 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
