Question about Logitech Cordless Wireless Optical Mouse for Notebooks 931006-0403
I cannot pan with the mouse in Autocad or Revit.
The mouse is properly installed. I used to be able to press the scroll button to pan across my drawings in Autocad and Revit. Not all I get is an uncontrolled jump.
I can move side to side slowly by pushing the roller left of right, but I cannot complete any kind of dymamic pan.
A friend got it to work once, however when the computer is rebooted the same thing happens. Very Frustrating.
  • 1 more comment
  • Anonymous Jan 12, 2009
    same proble here
  • Anonymous Feb 20, 2009
    I am alos having problems with my mouse in revit. The wheel will not pan or zoom. It just jumps around the screen.
  • Anonymous Mar 03, 2009
    I am having the same problem. I can pan by pressing the mouse wheel in model space but the extent of the pan is one short jump per press of the wheel. If I am on a layout tab and go to model space through a viewport I cannot pan at all.
  • 72 Answers
Go to START > CONTROL PANEL > MOUSE ..... Here you will find the Logitech settings. On the BUTTONS tab, you will see a diagram that numbers the buttons on the mouse as well as a table that shows what each button is assigned to. In this table, double click the number assigned to the mouse wheel (usually button 3) and reassign the wheel to MIDDLE BUTTON. This should restore your Autocad pans.
Posted on Jun 16, 2009
    Problem Solver:
  • 12 Answers
I have had the same problem. I fixed it by using a standart microsoft 3 button with roller mouse. I know that an optical/wireless mouse is more convenient but having things jump around on you can be even more annoying.
Posted on May 08, 2009
Thanks to blu scarab. the problem solved!
Posted on Feb 25, 2014
Can not get Microsoft 5000 wireless mouse to Pan in AutoCAd 09
Do you use the "hold middle click" way of panning? If so, check that in the Windows Ctrl Panel under Mouse, that the scroll wheel is set for middle click. Why this is not default on all new mice I do not know!
Aug 09, 2010 | Microsoft Wireless Laser Mouse 5000
I want the middle button to be "pan" in AutoCAD
Change CUI, let the scroll button be used for pan
command
Apr 19, 2010 | Microsoft Wireless Laser Mouse 5000
The middle wheel does not work as a pan option in my AutoCAD 2002 program . Run in vista. Dell mouse SN-H100009B
In your control panel in windows under your mouse options. Make sure that you have the middle options button selected. It could be windows vista has not select it.
Dec 04, 2009 | Dell U0636 Mouse
I have a dynex wireless optical mouse but my laptop will not recognise it
Have you installed the driver for the mouse? Did you install it before actually attaching the mouse's USB receiver? The driver should be installed first. You can download it here:
http://www.dynexproducts.com/productSearch.html?query=wireless+optical+mouse&mainSearchButton=
Scroll down to "Dynex Wireless Optical Mouse" and click on "English" next to "Driver:" in order to download it.
If you've already installed the driver and your computer still won't recognize the mouse, press the Connect button on the receiver, wait for the light to flash, and then press the Connect button on the mouse. The light should stop flashing and the mouse should be ready to use.
Nov 23, 2009 | Dynex Wireless Optical Mouse
Cannot use centerscroll wheel to click and pan
Your scroll mouse may not have a button built into the wheel.
Do try to push down on the wheel, though. Most (quality) modern mice have a button built in below the wheel that just takes a little extra pressure to use.
Sep 29, 2009 | Dynex Wireless Optical Mouse
My Logitech mouse is uncontrollable. I changed
It's probably one of two problems. Either you have spyware (install and run SpyBot, for example) or the scroll button is pressed too hard. Good luck.
Jun 24, 2009 | Logitech Cordless Mouse
Wheel will not do just a standard scroll
You should make sure that you have the LX7 Setpoint software installed to set the features you want. For the scroll button or button three if pressed, I have mine set to zoom (first selection). The scroll function of the wheel should be automatic. Go the mouse movement settings and set the scroll size to 6 lines. That should allow you to scroll your pages adequately. If this helps send a reply for others to view.
Aug 20, 2008 | Logitech LX7 Cordless Optical Mouse
Microsoft wireless laser mouse 5000
Assign a keystroke to the mouse, in this instance I assigned 'p' for pan (as per the .pgp file short cuts etc) against the scroll wheel click.
Click the scroll wheel, 'p' comes up on the cad screen, right click to confirm then the pan icon appears, hold the left mouse button and drag at your leisure. Yet to find a fix for Inventor.
Not ideal, but better than nothing at presnt.
Jun 08, 2008 | Microsoft Wireless Laser Mouse 5000
Mouse prob.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Apr 13, 2008 | Micro Innovations Optical Scroll Mouse
Google Earth
I have a LX5 cordless mouse that was part of my S510 desktop set. Prior to this set I had a seperate USB keyboard and generic optical usb mouse. I noticed after installing the SetPoint software that i lost all use of the middle mouse button. Here's how you can restore the use of the middle button. SetPoint reassigns the middle button so that it no longer functions as the default middle button function. This can be changed in the SetPoint configuration. (Look for the icon in your system tray) Click on My Mouse and select the middle button. It's number 3 on my list and was originally titled zoom, but, clicking on a button name will give you a picture of the button location on the picture to the left. Once you locate the middle wheel button, in column next to the list, under select task, select other, then from the drop down list, select middle button. apply and save your settings by clicking ok. pan and tilt will now work properly in google earth.
Jun 13, 2007 | Logitech MX1000 Laser Cordless...
Logitech Cordless Wireless Optical Mouse for Notebooks 931006-0403 Logo
5,852 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
