Question about AEG Lavamat 16810 Front Load Washer/Dryer
AEG lavamat turbo 16810 DOOR STUCK
My wash cycle has finished but the door refuses to open. I have repeated the wash cycle and also repeated the drying cycle and it is still stuck  any thoughts ?
Derek
  • dereksmith48 Dec 08, 2008
    I have a AEG lavamat turbo and the door has stuck in spite of going through 2 cycles to try to free it. I have unplugged for an hour . There is no warning display , all seems normal here.
    Any thoughts
    Derek
    Sergeant:
  • 399 Answers
Replace the wax motor /Door latch.as something in the lactch is getting cracked off or blocking the door to lock and unlock fluently.
Posted on Dec 08, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, If the door doesnt unlock even after unplugging, then its the problem with the door mechanism or the door lock failure.
If you are not sure about how to open the unit, contact a service person.
Good luck.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, an AEG Lavamat turbo 16810 makes use of an Electric door interlock or door lock mechnism shown below.
Possible causes could be:
  • component failure;
  • there is still water inside or the machine thinks that there is still water inside;
  • the door handle is faulty;
  • the controller/logic board is faulty.
Temporary workaround may include:
  • unplugging from the mains for an hour or so;
  • manually draining (messy);
  • try any cycle and then immediatelty "Cancel" after the unit has started to make its run.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 1,800 Answers
  1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door. the washing machine wont empty the water.
  2. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
  3. Door interlock jammed
  4. Door catch, handle, or mechanism broken
  5. ****** (a device that detects the motion of the drive belt fitted to many older Hotpoint washing machines which "pecks" at the belt when the door handle or button is operated) is broken or has fallen off
Do not take the lid off and reach inside the washing machine to try and release the door if the washing machine is still plugged in as you will be electrocuted.
  • 121 Answers
Electronic selinoid not realising. saftey feature, remove power to same 5min . circuit breaker may be best way.  then try again . may  need tech service
    Sergeant:
    Champion:
  • 304 Answers
did you got any error codes appear on the washer display.?
try to unplug first the unit for an hour.
keep us updated here.
Cycle won't start/start light flashing red
Probably a bad wax motor in the door switch or a bad control board.
Yeah you should call someoneif you're not a learned handyman.
Feb 06, 2014 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
My AEG lavamat turbo 16810 update, makes a rumbling noise when the pump runs. The filter is clear so I presume I need to remove a foreign body from pump. My question is how do I get to it. can you give...
I'm not sure if this model has an access panel with 2 screws at the bottom, but if not, An easy way to access is by tilting the washer against the wall and removing the bottom panel, Should be 4 screws. from there you can remove the hose and retrieve the debris from the pump most likely change. have a fairly good size bowl and towels close by to catch the water. make sure the washer is disconnected from it's power source. Hope this helps.
May 02, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16820 Lavamat-turbo
Hi
this sounds like the fill vavle is fauty you can check this if you have a muiltmeter.
remove lid and unplug the green soliaod and check to see if open circuit.
if so replace and should be ok.
regards
Mar 08, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
1,849 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
