Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 stops in middle of cycle, flashes F-11.
Our Kenmore washer HE3 stops in the middle of a cycle and flashes a F-11 code. We have had 2 repair people out and give different answers. We are ready to throw it out the window. We unplug it and once we try to start again it gives the door lock code. Please help!
  • 2 more comments
  • sjsmccoy Dec 08, 2008
    model number 11045862400
  • Anonymous Dec 09, 2008
    f-11 code. not even 2 years old.
  • Shaun Plencner
    Shaun Plencner May 11, 2010
    what is ur model number
  • Anonymous Mar 27, 2014
    In the middle of the cycle the kenmore door locks, the 11 error message shows.
  • 251 Answers
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on Dec 08, 2008
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore he3 washer stops mid cycle with no fault codes
could have a bad computer board or i've seen this happen with a bad door switch,but this is just guessing,there should be a tech sheet,remove the bottom panel and look around for the tech sheet taped to the side wall,it will tell you how to run it in diagnostics mode and how to bring up any error codes.always problems with the main ccu computer board
Mar 29, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Kenmore elite he3 model 110 f-06 code comes on and washer stops .
I was getting a F-xx code can not remember the number.
If you remove the bottom front plate , I remember 3 three screws.Behind that is the filter for the machine, mine had a 2-3" white cap that came off with a screen inside that was plugged. When you open it up you can get a fair amount of water come out. The machine will not work until you put the front cover back on.
UNPLUG the machine FIRTS
Aug 23, 2012 | Kenmore Washing Machines
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
348 people viewed this question
Sal De
 Brian Main
Brian Main
