Question about Pioneer TS-W33C Car Subwoofer
Pioneer ts w33c
HI everyone well this IS NOT A PROBLEM more or less general knowledge i just got these pioneer ts w33c subs and i want to know what kind of a box i should build for max peformance i have a pioneer deck forget the model and a kennwood kac 8101 amp i wanted to know how big and if i sould go ported or completlet sealed or have a divider in between the two subs ? thanks for the help!
  • 944 Answers
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Posted on Mar 09, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 16, 2007
    Also just found this for another user - not for your model, but the technical details of box construction etc are extremely good - might be worth a read;
    http://www.kicker.com/06/tech-support/ma...
    Hope this helps :)
What size of box in need Pioneer TS-W310D4
if its pioneer shop at walmart lol !!! try a speaker shop or read the manual it has that kind of info in it
Feb 25, 2013 | Pioneer Ts-w309d4 tsw309d4 1400w 12" Dual...
If i put the TS-swx310 sub in a bigger box would it get help the sound.......i have a 12'' regular sized box and the speaker is going in a car now???
It is amazing the difference box construction can have on the overall sound of a system. Size is only one factor. Using a larger sealed box may make the sub hit lower, but not necessarily louder. Because the TS-swx310 is a shallow mount woofer, it is designed to run in small enclosure. Putting it in a much larger box could potentially cause damage to the woofer over time. If you want more bass my advice is to use a normal woofer in a box built to spec for it. Generally a ported box will provide more output, and sealed hits tighter. It all depends on the type of music you listen to.
Hope this helps
Please Vote & Rate
Mar 08, 2010 | Pioneer TS-SWX310 Car Subwoofer
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What is the optimal volume for a speaker box for two Pioneer TS-W26C sub woofers? I know that enclosure speakers have an optimal volume for the boxes, however, I can not find out what the optimal volume...
try this site very hepfull if you can find all the speakers spec's.http://www.ajdesigner.com/speaker/ajvented.php . if you have the latest pioneer speakers they were designed for small enclosures if you imput speaker code in to google search you should find all the details you need .
Sep 05, 2009 | Audio Players & Recorders
Pioneer box
Thanks for using fixya!
I have had the same problem that you are having right now. I basically don't know how to start making my own sub box. Well, I chose the Bass-reflex type Box. This the best. Check this link out for a detailed overview of sub box making. http://www.hardwareanalysis.com/content/article/1789/build-your-own-10-inch-subwoofer/
Have a great day.
- HotRatchet
Jul 26, 2009 | Pioneer TS-W307D4 Car Subwoofer
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
SUBWOOFER ENCLSURE FOR TWO PIONEER TSW307F 12" FREE AIR
Hi, i know its a long time since 2008.
but do you or enyone else know where to get specs to a pioneer ts-w307f???
im building a box for this sub but i cant find specs so i cant run it on winisd!
i konw this dont answer a qestion but since you did a graph on it in winisd i thought you might have the right specs?
Dec 24, 2008 | Alpine MRV-F307 Car Audio Amplifier
Spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Recommended vented box volume for tx-w307d4
pioneers are subs u have to be careful with, some subs are made for ported boxes and some arent, check if it is, tham if it is it should b tuned to about 35hz-45hz.
Nov 28, 2008 | Pioneer TS-W307D4 Car Subwoofer
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Mar 27, 2008 | Pioneer TS-W301R Car Subwoofer
Pioneer TS-W33C Car Subwoofer Logo
288 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
