Question about Sprint Hitachi P300 Cellular Phone
TV model no L32A01A NA - we have sound but no picture
Have checked all connections and all seem ok the monitor comes on for two or three seconds then goes blank
What problem my lcd sound ok but no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 07, 2014 | Sansui HDLCD-3212 32 in. LCD TV
Tcl tv model no dn2127h sound ok but no display
- Flickering screen
- Dim screen
- Slow start
Apr 11, 2014 | Televison & Video
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Check to make sure you have the right input selected for the input that ou have plugged into.
Jan 20, 2013 | LG 42LC7D-UB Television
Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Jul 18, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
No picture when TV is turned on, sound is OK
try to look at its circuit board and look for cold solder or loose solders usually solders with crack,they might be the problem,i dont think its the flyback coz you have audio.try also look at its picture tube at the back tru the crt if the filament is ok or it may also have loose connections
Jan 13, 2009 | Samsung TXJ2554 TV
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Dec 08, 2008 | Philips 60PP9202 60" Rear Projection...
Sony Grand Wego - Sound but No Picture
Before I commit myself, I need a little more info. First, what is the model number? Second, in the front there should be a standby light. does it blink at all? It should blink in a repeating pattern. If so, please post that too.
Thanks,
Dan
Sep 23, 2008 | Televison & Video
No picture
My model no is 42LV3400 BTMYLJT and serial no is 111THQL00668.and expire date is 24-02-2013.thi is running Ok. but yesterday tv is running after tv screen is OFF. but sound is OK.
Jun 21, 2008 | LG L1932TQ LCD Monitor
Problem with picture
Most likely it's the LCD panel assembly failure. Either the inverter board or scaler board.
Jan 18, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sprint Hitachi P300 Cellular Phone Logo
146 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
