Question about Compaq Armada E500 Notebook
Non-disk or disk error
It says this when i start it up and never goes away...... ive tried everything! please help me!
    Scholar:
  • 37 Answers
If you have a floppy disk in the floppy disk drive remove it.  If not then take out your hard drive and put it back in it may have lost connection.  if not im sorry to say your hard drive probly is not being read correctly and should be taken out and tested.
Posted on Dec 08, 2008
1782 disk control failure / non-system disk or disk error That is all it does
That means, there's an error reading the files of windows system, or something else to start your Operative System.
Try to reinstall your windows.
If you get errors when you try to install the windows, tell us the error on the installation. It can be an Hard Disk problem and you must replace it.
Dec 10, 2013 | Compaq Evo N800c Notebook
Cannot open my laptop... Did everything from removing the battery, cleaning the fan but still screen says non system disk or disk error replace n strike any key when ready.... Help pls
Please try the following:
1. Remove the non-system disk from your boot device. For example, remove the non-system disk from the CD-ROM drive. If there is no CD or remove the floppy disk from the floppy drive.
2. Change your computer's boot sequence. To do this, you must change your computer's setup and the option that controls which device your computer uses to start from. Make sure that you select a device that has boot files (or operating system files) installed. Normally, this would be your hard drive.
Oct 19, 2012 | Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Hello, ive just bought a brand new motherboard (GS7610 ULTRA) and i have installed it into my case with all my components and when i go to start my computer up, it goes pasted the boot menu and then i get...
Are you trying to install this OS (Operating System) , or is it already installed on a hard drive?
If you are installing it, make sure you change the boot order to the optical drive (DVD drive). If it's already installed, was it installed with an OEM disk? If yes, then you might need a new Windows XP disc. This is because, when using an OEM disc, if you change the hard drive or motherboard, it doesn't really work.
Sep 24, 2011 | EliteGroup GS7610 ULTRA Motherboard
I have an acer one 8.9" laptop. I down loaded a torrent that stopped and started a few times and said I had a bad hard disk. Now I cant get past the acer start up screen. Ive with the external disk drive...
Try re-starting in safe mode, press F8 as its booting, assuming all goes well choose safe mode, this loads a windows shell. Using Accessories - System tools - System restore - Restore to a point prior to your problemsn.
Sep 21, 2010 | Acer Computers & Internet
Windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
May 21, 2009 | Toshiba Satellite A135-S2276 Notebook
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
Mar 05, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Dec 29, 2007 | Computers & Internet
Non responsive program msg on admin.log in or out ,closedown windows,end yahoo email,games,. very very slow computer
Use hijack this.....sounds like you may have a virus or trojan (most likely)....read instructions carefully but feel free to delete (when using HIjack this) anything that looks strange....also I assume you have a good virus checker (Avant or Avg both of are free) and Spybot search and destroy or equivalent.
Nov 17, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Compaq Armada E500 Notebook Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
