Question about Acer Ferrari 4000 Notebook
Acer 8100 Travelmate - blank screen
The
Acer Ferrari 4000 "power on" blank screen, fan is running but no beeps, no activity in/from the HD. No reaction on a F8 start up (no Bios set up). It charges the battery OK.
KR Steen Larsen
Posted on Nov 11, 2009
  • 70 Answers
Tell me the problem in detail. or mail me at sil_techindia@yahoo.co.uk
Posted on Aug 23, 2009
3 Suggested Answers
GuruGrundy
  • 64 Answers
SOURCE: Blank screen
Seems like the connection might not be setup correctly inside the laptop. Check for bent pins for where the lcd screen connects to the motherboard, and also make sure any "ground" screws are in like they were if there are any.
Posted on Mar 20, 2009
bronk50
  • 27725 Answers
SOURCE: my acer travelmate 8100 turns on but screen is blank
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Posted on Aug 21, 2012
Replace keyboard on acer 8100 series laptop
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
http://www.papatek.com/Acer-Keyboard/Acer-Travelmate-8100-keyboard.html
Jul 23, 2010 | Acer Ferrari 4000 Notebook
Laptop screen goes blank randomly
Hi you can try this in Vista
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
  3. If you are prompted by User Account Control for permission, click Continue.
  4. At the command prompt, type the following command, and then press ENTER: powercfg.exe -h off
  5. Type exit, and then press ENTER.
Windows Xp;
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options. click the Hibernate tab and unckeck the box and turnoff monitor should be never
Sep 16, 2009 | Acer TravelMate 5520 Notebook
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Blank screen
Mar 20, 2009 | Acer Ferrari 4000 Notebook
Acer travelmate 212t problem
It sounds like video card problem. Bring it to a repair shop.
Dec 10, 2008 | Acer TravelMate 212T Notebook
Black screen
Sounds like the inverter that poweres the backlight is dead. Search on eBay for the FL inverter for your model. Should be easy to replace.
Jul 04, 2008 | Acer TravelMate 2500 Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Computers & Internet Logo
429 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
