Question about Xerox WorkCentre M15i Laser Printer
WHEN YOU SEND A FAX IT LEAVES A LINE HALF INCH BLANK DOWN THE RIG
When sending a fax it leaves a blank line down the right side a half inch wide.
    President:
  • 2,072 Answers
Does it also leave the line when you make a copy? Lift the lid and make a copy cover up. If it is there on the copy then most likely your scanner needs to be cleaned. If it isnt there when you copy, let me know we will go from there.
Posted on Dec 08, 2008
Have a Okifax 5400 - changed toner and drum but still getting blank line down side of the page. Any way to fix?
clean the LED array with a soft cloth or tissue or the alcohol wipe that comes with new toner cartridges if you still have it. open the cover to expose the drum on the bottom side of cover is a black bar(LED ARRAY) as wide as the drum but about a half inch thick wipe the bottom side that will face the drum when the cover is closed
May 21, 2010 | Office Equipment & Supplies
Line goes through page when fax is sent
Open up the document feeder and clean the small glass. If the line is more than 1/4 inch wide you have a bad scanner block.
May 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
When printing or faxing there is a one to two inch blank spot
INSPECT THE DOCUMENT READER GLASS THIS SOMETIMES GETS WHITE OUT OR OTHER JUNK ON ON THE LENS AND LEAVES A VOID AREA.
Feb 19, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
White vertical line on received faxes
hi,
The upper glass is under the drum unit.
- Remove Toner and Drum Unit and you will see the glass. Try to clean it.
Bye.
Dec 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Scanner locked on my xerox 2218
Its easy to fix. Turn the machine off, then look in the area where the copies comeout. Where you reach your hand in to remove the copies or received faxs. Squat down and look on the inderside of the scanner in that area. You will see ONE green item, it is the scan lock. It's about an inch and a half long and about a half inch wide. Shove it in, toward the back of the machine, then pull it out toward you until it snaps back. It may be a bit tight and may require a pretty decent pull back.
Once you snap it toward you, turn the machine back on and it should be ready to go.
Oct 23, 2008 | Xerox FAXCENTRE 2218 18PPM FAX
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
Xerox WorkCentre M15i Laser Printer Logo
196 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
