Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Vertical line on teh left side of the screen
Line started about 4" from the top but has now ran the full legnth of the TV. It is a black line and appears to a "crack" on the inside of the TV. The line is visable when the TV is off. 52" Bravia XBR. TV was purchased in February of this year.
  • homerg Dec 27, 2008
    I have the same problem with Sony KDL-40S2010. A vertical line appeared on the left side from top to bottom when turned on without connecting to cable line.
  • pekks Jan 05, 2009
    I have the same problem. It was only a small line on the first day and next day it is 3/4 th of the left side screen vertically. I have a Sony 40s2010. Please help...
    Genius:
  • Sony Master
  • 1,689 Answers
It definately looks like a mechanical defect with the screen. If you see the line when the set is shut off this means that the screen may have a crack in it, or there is a defect in the substrate.
This type of fault is fixed by replacing the screen assembly. The cost of this would not be worth it.
Jerry G.
Posted on Jan 31, 2009
I have a cub cadet 7260. It ran out of diesel and I can't bleed it to get it to start. It's a 1998 model
I don't now the cub worked but diesels, should a plug or screw on top of fuel filter. first make sure your fuel tank is 3/4 full. lo. pump ose screw wait till fuel run out. close screw. if your lucky you have a fuel pump pump it up till feel pressre. PUMPING IT SLOW CRACK A INJECTOR LINE TILL FUEL COMING OUT. CLOSE LINE AND GO TO NEXT ONE AND NEXT
Jul 23, 2017 | Cub Cadet Garden
I have a Ryobi s430 that starts and runs and throttles up fine when level but will stop if I tilt it to start using it even if I have the throttle pulled. Acts like its bogs down when not level.
Investigate the fuel line inside the fuel tank. Sounds like it may be split or cracked, or broken off. The line has a weighted pick up filter, and it is very common for the line to crack or break off so that when tilted, the line is above the fuel level.
Feb 25, 2017 | Ryobi Garden
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
How do I resolve a problem with a black vertical line that's appeared approx. 2 inches from the left side of the TV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 27, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
422 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
