Question about Fuji FinePix S3100 Digital Camera
My Fuji finepix S3100 battery cover is broken off can it be fixed
I have fuji finepix S3100 and the place where the batteries go is broken off and I know if has to be lined up perfectly to work and I just want to know if I can buy a new cover or if it can even be fixed
Posted on May 10, 2009
I have a fuji flim s3100 camera,i need a finepix
Please visit fuji's website and search for downloads.
Dec 23, 2009 | Fuji FinePix A345 Digital Camera
Fuji finepix e510 won't turn on
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Jan 18, 2009 | Fuji FinePix E510 Digital Camera
Fuji S3100
I think problem is under the lid where batteries go a residue forms. like the same stuff that forms near your car battery terminals. ??
May 10, 2008 | Fuji FinePix S3100 Digital Camera
Fuji FinePix S3100 will not turn on.
Sorry, no real solution. My friends have one that would not turn on and they left it without batteries for a month, then put the batteries in and it worked. Mine has failed and will not turn on. I have left the batteries out but nothing has miraculously fixed itself yet. May have to send it in to Fuji.
Apr 29, 2008 | Fuji FinePix S3100 Digital Camera
Fuji FinePix S3100 won't turn on
there is a option in the menu that turns the camera off after 2min. and then after that it is hard to get started.I took out the rechargable batteries and installed new duracell batteries,and it started and then I went to the menu and disabled the powersaver option.
Apr 16, 2008 | Fuji FinePix S3100 Digital Camera
Fuji S3100 Broken Battery Latch
There are two potential solutions that I know of, but only if the broken tabs are on the door and not the camera body. Double check which tabs are damaged.
The first involves getting a new door somewhere (good luck with that... Fuji doesn't seem to sell the parts to civilian consumers... you might try getting the part from an old non-functional one on ebay or something). The trick to removing the battery door is to push the door's hinge pin (with the door open) towards the back (LCD side) of the camera from the opposite (front) side. There is very little clearance. I have successfully used a paint can opener to do this on a S3100. You can brace the back side of the opener against the lip of the camera body and push the pin out. Once it is as far out as possible, use needle nose plier or tweezers to grip the now exposed end of the pin and pull it all the way out. Then put the new door in place and re-insert the pin... there may be a little resistance.
The other was recommended to me by a camera repair man, but I have not tried. I would probably have let him do the work, as it seems a little risky, but possible. It basically involves getting a small washer that will fit under the two latching tabs near one another on the body. After figuring out the correct position for the washer to be attached to the door that it will just slide under the tabs and secure the door, you must use a small countersunk screw through the central hole in the washer to attach it to the door. You might have to remove the rim of the door in that area with an exacto knife or something similar so the washer will fit well. Like I said, I would have probably let him do the work, but it sounds like it would work.
Another idea that just occurred to me is a little more work intensive but would probably work would be to sink a (coarse thread) screw through the door all the way into the plastic of the body (maybe 2 or 3 in different places), which could simply be unscrewed any time you wanted to change the batteries with relatively little trouble.
Good luck! =)
Feb 08, 2008 | Fuji FinePix S3100 Digital Camera
Fuji finepix S3100
Check these three sites.;_ylc=X3oDMTB0bjZzaWNuBF9TAzk2NjMyOTA3BHNlYwNmZWVkBHNsawNlbGVj
Which battery does it look like?
Jan 31, 2008 | Fuji FinePix A350 Digital Camera
Fuji FinePix S3100 Digital Camera Logo
155 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
