Question about Fahrenheat FBE15002 Baseboard Heater
Baseboard heater yes, my baseboard heater located in the bedroom won't shut off the button is not clicking. The heat as been on for one week in this room. what can I do? Please Help me? thank you
  • 51 Answers
The stat points are stuck together or the stat is defective. try tapping on it to make them loosen up or replace the thermostat.
Posted on Dec 08, 2008
My baseboard heater isn't coming it likely the thermostat? It's from the 1960s. Do you agree?
Could be. If you have a meter check power to and thru the thermostats. It may be hard to find thermostat . You may be money ahead to buy a new one. It will be more efficient.
Oct 21, 2017 | GE WB27X10810 General Electric Thermostat
I am interested in purchasing baseboard heaters, particularly I have been looking at the Farenheat PHH15002 baseboard heaters. I am purchasing an 1100 square foot 2 story condo with 2 bedrooms and a...
#1 you have to calculate the heatloss of your rooms,that will tell you ur wattage require. Oil filled or not,it's just as dry. As far as ur load to panel breakers, a rule of thumb is approx 3600 watts for 20 amps,using a number 12 wire. But ur wall heaterS should suffice
Apr 21, 2017 | Fahrenheat PHH15002 Oil Filled Baseboard...
I am puchasing a 28 YO home with electric baseboard heating. Will this be satisfactory or have there been much advancement made in baseboard heating used today?
To put it simply; any other heat source is better than your existing baseboard heaters. Yes, there have been sincere advances. Here is an informational website:
Hope this helps some:)
Aug 30, 2010 | Fahrenheat Electric Convector Baseboard...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Burning Smell from Old Baseboard Heather All of a Sudden
If it was the first time started this season, then it was dust buildup burning off. If burning smell continues, call for service.
Dec 15, 2009 | Cadet Manufacturing 4F1000-8A Electric...
Electric baseboard heater worked last week. but when I
The wall thermostat will click even if there is no power. You will need an electric metere to trace down the problem. May be a bad breaker, bad limit switch or the element could have went bad. You need to follow the electric and see what is interupting the flow.
Nov 12, 2009 | Fahrenheat FBE15002 Baseboard Heater
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Fahrenheat FBE15002 Baseboard Heater Logo
207 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
