Question about Technics Audio Players & Recorders
Technics SC-CH515 CD Tray Does Not Stay Open
I recently purchased this system (second hand). When at the owners house to take a look at it, the CD tray would not stay open. When you press the open/close button it opens fine, but it closes immediately without giving you a chance to put CDs onto the tray. The guy told me that this had happened to him a few years back and that he ran a CD cleaner disk through it and that it fixed the problem. So, for the price that I was getting it at, I decided to take a chance... I purchased a disk cleaner (no liquid, just brushes on the disk) and a can of compressed air (we figured it was a sensor problem since the mechanism seems to work fine as it opens without any hesitation) to try to fix it. After using the compressed air it worked fine - once. After that it went back to its' old tricks. Other that that, the system works / sounds fine. Any help would be appreciated.
    Scholar:
  • 107 Answers
I DO NOT think that problem related with CD cleaner
3 possibility here
1 The loading belt was lose it can not open fully to reach the switch open when the time limited was out as program design from system control it automatic close
2 The loading gear system out of position 1 tooth
3 Dry joints on switch open and close or connector from CD tray to system control intermittent contact
In any case it require a qualifier Tech from Panasonic to reset the timimg gear or service
I hope that give you some ideas if you need further info or service manual I am willing to help you out
Cheers
Posted on Dec 10, 2008
Technics SC-CA 1080 CD player jumps ,can I just buy any CD player separate and connect it to my technics? It's a separates 'style' system, not sure if its compatible with a different CD player
You have tried cleaning the lens? That might cure the jumps. Make certain your CD's are not scratched and clean too.
A separate CD player will work with your system, I think. It looks like the current CD player will connect via two phono plugs to the back of the system. Since the new CD player will have the same type, just remove the old connections and the power lead and plug the new CD player in the same phono sockets. As the new separate CD player will have it's own power supply it will not need the old one.
No further adjustments are needed. Any brand of CD player can be purchased.
Jan 21, 2016 | Technics Audio Players & Recorders
Ive just moved house and set my technics sl-dv290 sterio up and keeps saying dvd and the cd tray wont open has anyone got any ideas why this is happening and how to fix it please
Most likely, the microprocessor(the computer within your unit), will not allow any input changes. This microprocessor controls both remote as well as front panel input switches.
If you are interested in having your Technics repaired, please look to my website at audioserviceclinic.com. Thank you.
Aug 03, 2015 | Technics Audio Players & Recorders
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
My Panasonic SA-PTX7 doesn't open cd tray. help
I really like my SC-PTX7. But when that happens to mine I reset the unit. unplug, wait 15 seconds, plug back in, fixed!
hope that helps.
Nov 11, 2010 | Panasonic SC-PTX7 Home Theater System With...
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
Technics manual sleh600
Technics SL-EH600 is CD changer, which is part of SC-EH600 syste, so download:
SC-EH600 Manual, scroll to pages 18-21 for SL-EH600.
Feb 24, 2009 | Technics SCEH790 CD Shelf System
3-disk cd tray will open & then immediately close
I would suggest using Servisol Video 40 spray to clean any contacts inside the machine.
Mar 26, 2017 | Memorex MKS5001 Shelf System
TECHNICS SC-EH750-CD KEEPS SKIPPING
replace travers assy ,because spindle motor is faulty. If you can get spindle only it will be chiper solution for you.
Nov 10, 2007 | Technics SC-EH780 CD Shelf System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
894 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
