Question about LaCie (301065U) 500 GB USB 2.0 Hard Drive
My hard drive won't show up on the mac
My roommate saved my work on the mac and shutdown the computer but i don't know if he ejected the drive and now a folder pops up with the name of the hard drive but nothing is in it and its a folder symbol not the USB drive symbol. I just wanna know if i use the lacie software cd will that help it re recognize itself on the mac. oh and By the way it still works on PC
  • 2 more comments
  • Diane Hyppolite
    Diane Hyppolite Dec 08, 2008
    no it's saved. The hard drive just isn't showing up on macs and i've tried it on 4 and just waited. Its on but its just not reading but when i plug it into a PC it reads
  • Dominic
    Dominic May 11, 2010
    File Allocation Tables (FAT) function much differently than a journalized file system like NTFS (aka HP Unix File System) or the Mac OS filing system (aka BSD Unix File System). While FAT filing systems are more compatible it performs poorly with larger disk spaces. Whenever a journalized file system is improperly mounted the system replays the journal the next time the partition is mounted; if a critical error is detected the system will begin a repair process. (No critical errors detected does not mean that there is not a problem with the file system.) After a repair process completes the system needs to be rebooted twice for the changes to take effect. With that being said, Mac OS could be detecting a problem with the file system when it plays back the journal which is keeping it from mounting. I'm assuming this is a hard drive in an external enclosure, plug the drive into the PC and run a file system check.
    • Open "My Computer"
    • Right-click on the portable drive
    • Select "Properties"
    • Left-click the "Tools" tab
    • Left-click "Check Now..."
    • Make sure you put a check in the box for "Automatically fix file system errors"
  • Dominic
    What format is the hard drive partition in? And what verion of Mac OS are you using? Is it formatted with NTFS?
  • Dominic
    Is the work saved missing from the hard drive?
    Novelist:
  • 167 Answers
Mac OS can not repair a non-native partition like NTFS and will not mount a drive with errors. Repair the drive on the native system and this should resolve the problem.
Posted on Dec 08, 2008
Useing Hard drive on a Mac computer(Hard drive Isn't showing up on computer)
It could be that it's either not partitioned properly, or if you've used it before it might not have been ejected properly the last time it was disconnected.
Some drives that say they are Mac compatible must be partitioned for Mac before they become accessible. Based on the brief description that's the only advise I can offer at this time.
Nov 06, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
External hard drive used on mac,how do i use it on pc?
You need to format this hard drive using your PC.
If the hard drive was formatted using the MAC then the PC won't see anything on the hard drive because the MAC uses a different file system that is not compatible with the PC.
BUT if you want to exchange files between the MAC and the PC then format the hard drive using the PC in FAT32 file system. The MAC can read and write to a FAT32 formatted hard drive.
Apr 10, 2012 | Hitachi Computers & Internet
I have a mac and a new iogmega external drive, 500g. I cannot move any files onto the iomega or save them. I get messages such as "that file does not exist" to iomega can't be modified,...
With the drive plugged in, going into your Applications ' Utilities ' Disk Utility Select the drive and press Verify Disk, Repair Disk and Repair Permissions. If you don't have anything on the drive right now, try formatting it with the Mac OS Extended (Journaled) file system from the Disk Utility.
If that doesn't work the drive may be damaged. If you have another PC / Mac, trying plugging it in and see if it works there. If the drive is under 1 year old it should still be under warrantee, in which you could return it / RMA and get a new one sent back from the manufacture.
Regards, Chris
May 31, 2011 | Iomega (33090) 250 GB Hard Drive
My Avastor HDX Portable HD drive just crashed. I had it connected to my Mac, and when finished using it I wanted to eject the disc but it wouldn't, whatever i tried. So i disconnected it anyway. But...
Hi!
i dont know if your drive is dead , but try to connected to an Other Pc with different System (windows Xp Or 7 ) and see if it work try to formate it , but if he didn't work that's mean is dead ,
good Luck
May 23, 2011 | Avastor HDX-800 400 GB FireWire 400...
Unable to safely eject
Just completely "shutdown" your computer, and then disconnect the USB cable. Then, you should be able to manually "eject".
Apr 17, 2010 | Verbatim 160GB USB FireLite: The "drive...
When I put my mac in sleep mode and restart it I get a message that says I have not put my lacie hard drive away right. How do you do that.
The message you are getting is refering to removing the Lacie before disconnecting it.
Just as you eject a drive before unplugging the cables to prevent corruption you must do the same before going to sleep as turning off the power to your USB ports(which happens in sleep mode) is no different than unplugging the drive without ejecting the drive when the computer is running.
If your Mac is set to go to sleep and save power when it is not in use then you should only plug your Lacie in when you are using it and should eject the Lacie before going to Sleep.
Failure to do so will eventually result in a loss of data.
If you have already lost data from a Mac formatted Lacie drive then you should refer to the below link for assistance in recovering your files, if not simply follow the above steps and you should not have any problems as a result of your Mac going to Sleep.
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Feb 11, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External hard drive can not be read by the computer
The hard drive was originally formatted for a PC and I was using it with Mac products. I had to delete all the information on the hard drive so that I could reformat the external hard drive to work with my Macbook Pro.
Dec 08, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Putting pictures on the computer
This looks like a Mac USB problem. Is there a Mac forum website for you to consult?
Jul 27, 2007 | Fuji FinePix A400 Digital Camera
LaCie (301065U) 500 GB USB 2.0 Hard Drive Logo
209 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
