Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
Date time setting does not program
Each time I turn on my camera, I need to reset the time zone, date and time. Any suggestions on how to remedy this? Have I missed a setting somewhere. The camera is 6 months old and I am not entirely familiar with all the functions.
  • 1 more comment
  • Saima Horab Feb 28, 2007
    I checked the manual and it indicates that there is not a backup battery for this camera. It states that the date and time will reset if the camera is not powered by the battery or cradle for more than 30 hours. I have charged the battery, and the battery indicator is full. The camera seems to be working perfectly except I need to reset everytime I turn it on?
  • timjpost Nov 08, 2008
    I also must set the date and time every time the camera is turned on. I removed the face plate and some components to look for the backup battery and couldn't really see any to speak of (I assume it would be a small 3 volt or hearing aid battery).
    My manual also says that this camera somehow saves settings without a back up battery (perhaps it uses a capacitor or very long life, low outpt battery, like a thumbdrive), so I'm not sure it even has one. If it indeed uses power from the battery to save settings (hence the 30 hour rule), but the camera turns and takes pictures fine, so the connection between the battery and at least the "awake" part of the camera doesn't seem to be an issue.
    Well, I just read the manual more closely and it's actually ambiguous. On page 16, the manual says, "this camera does not have a separate battery for the clock." However on page 48, it says, "A built-in backup battery retains the date and time settings of the camera for about 30 hours if the camera is not supplied with power."
    I don't understand though, how even if the backup battery is dead, the main battery wouldn't provide power to save the settings.
    I've also upgraded the firmware, formatted the internal memory, and performed a reset through the menu.
    New Friend:
Thank you, thank you! This camera (Power Shot A510) does have a backup battery that is easy to get to. Under the rubber flap where you connect the cable, there's a little door you can pull out with your fingernail. There is a CR1220 battery - can be found at any jewelry store, as it is a watch battery. I replaced that and viola! No more messing with the date/time every time it powers off/on! THank you so much!
Posted on Jun 05, 2013
For those having problems with having to enter the date/time everytime you start the EXILIM Z/S series camera .. the solution is simple - press the SET button once date is entered. I had this problem for 2 days .. couldn't figure it out. Then realised that I had been pressing the 'MENU' button once entering the date. This of course doesn't save the date and the camera keeps asking your for a date everytime you turn it on!
Posted on Jul 02, 2007
    Novelist:
  • 107 Answers
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Posted on Feb 24, 2007
SOURCE:
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
Sep 29, 2018 | Time Computers & Internet
I cannot reset time and date on my samsung z2
Want to set the date and time for your mobile phone? Follow these easy instructions.
From a Home screen, tap the Arrow icon to display all apps.
  1. Navigate: Settings > Date & time.
  2. To use network-provided values, turn on the following:
    • Automatic date & time
    • Automatic time zone
  3. When manually setting data & time, perform the following:
    Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
    1. Tap Set date.
    2. Adjust the date then tap OK.
    3. Tap Set time.
    4. Adjust the time then tap OK.
    5. Tap Select time zone then select a time zone.
  4. If desired, tap Use 24-hour format to turn on or off .
May 23, 2018 | Samsung Cameras
How do I change the time on my lgl34c
go to settings and select date and time.turn off automatic date and time and set the date and time to what you wish
Sep 27, 2014 | Cell Phones
Date keeps resetting, when camera is turned off
hi, the problem why evrytime you turn on your camera you need to be set the date/time is the capacitor inside of the camera you need to do is replace with new one.it is easy if you now how to repair electronics or if you have knowldege. try to bring to service center and for sure they will charge a minimun charges.
Jul 08, 2010 | Olympus FE-340 Digital Camera
I cant open my yahoo.mail
Check the time zone on your computer versus the time zone in the Yahoo profile they need to match as this could be synch error.
To check the time zone on your PC Double click on the clock in the lower right corner. Then Check the time date year, then time zone.
Sep 21, 2009 | Yahoo Messenger
Set time zone initially when phone was first turned on, now can't reset time or date.
just go to settings and set the time and date and you will have the option in settings like zone time there you can check the zone and you can set the time.
Sep 17, 2009 | Nokia 5320 XpressMusic Cellular Phone
Have to reset date and time every time I turn it on!
If you have to do that each time you shut it off and turn it back on try this. Take your memory card out and format your internal memory. Reset the camera and then re-enter the information. Shut the camera off and turn it back on and hopefully it will still be in there. If not then you have an internal memory error and that needs to be fixed by Casio.
Aug 24, 2008 | Casio Exilim EX-S600 Digital Camera
Hi - I have a Rebel XT - and my built-in flash won't work - and i get an ERR 05 message. What can I do?
Dear joefrisco:
An ERR 05 message indicates that the camera's flash pop up mechanism has encountered a problem due to either an obstruction (such as your hand or something blocking it), a jam (impact damage), or an electrical failure.
Try the following steps, in order, to try and resolve the issue. If nothing works, the camera will have to be sent in for service (call Canon Tech Support @ 1-800-828-4040):
1. Turn the camera off. Ensure that nothing is blocking the pop
up flash. Turn your mode dial to one of the Creative Zone
modes (P, AV, TV. or M). Now turn your camera back on
and attempt to take a flash shot. You will need to manually
press the flash button to do so.
2. Turn your camera on and perform a hard reset by pressing the
MENU button, tabbing over to the Set Up 2 menu tab and
selecting the option "Clear Camera Settings / Clear All
Camera Settings" options, and then removing the camera
batteries, date/time battery, and memory card for a period
of approximately 2 minutes. Then reinstall all items, turn
your camera on, reset the date and time and perform step
number 1 above.
Hope this helps.
Sincerely,
HeavyDLB
Jun 02, 2008 | Canon Cameras
Set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
810 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
