Question about Nintendo DS Lite Console
DS Game port
There are 2 wires bent inside the ds slot game slot on my son ds lite. I have the back off the unit. My question is can I unsoldier the corners of the metal cover and straighten the wires without doing any more harm. Or where can I buy a new port to replace this one.
Thanks
Robert
    Problem Solver:
  • 5 Answers
Buy new socket from
http://stores.ebay.co.uk/the24hrphoneshop_NINTENDO_Ds_W0QQcolZ4QQdirZ1QQfsubZ362833012QQftidZ2QQtZkm
Posted on Dec 11, 2008
My sons DS lite is having issues with the games clicking into the slot. The games go all the way into the slot but wont click into place, and they will play if i hold the game in. I've looked in the slot...
The spring that holds the game in place is broken and needs to be replaced. at some point someone may have snatched the game out instead of pressing it in then ejecting it. Here is a link to another moms story about the DS http://headbonk.com/blog/2009/04/12/nds-silver-slot-1-repair-sort-of/ I hope this helps and I hope its just gunk stuck in the bottm of slot 1 thanks in advance for your feedback
Dec 29, 2010 | Nintendo DS Lite
I have a nintendo ds lite, that is older but only used a few times. My son just stuck a metal object in the back game slot while he was playing pictochat and the whole thing shut down and will not turn...
needs main fuse ( F2) repalcing
they are surface mount ( solder) fuses and small (1.3mm)
for any more help see www.dsdoctor.co.uk
may also need a game slot if pins are bent :-)
Jun 19, 2010 | Nintendo DS Lite
DS Lite no longer recognizes games when they are inserted
My best suggestions for resolving the bent/ broken slot-1 pins are:
1) If under warranty then send it off to them for repair.
2) Find a local repair place and give it to them to repair it.
3) If you have good soldering skills and fancy a bit of DIY repair you can have a go at sorting it yourself.
To be honest its far easier to just replace the entire slot-1 part than it is to take the part apart and repair it, the cost of the slot- 1 is very reasonable from ebay.
I have a few guides written up to help you if you do decide to take the DIY option, they are as follows:
DS lite slot-1 replacement guide
DS lite dismantle guide
Hope this helps, any further help or advice you may need then feel free to contact me.
Regards,
SOD69
Mar 13, 2010 | Nintendo DS Lite Console
Ds lite saying no ds card and no game pak inserted
Defecttive Slot 1
Look inside with a litte light. You will almost certainly see bend pins. You son has almost certain play with someting sharp inside the connector.
Slot1 must be replaced
Apr 21, 2009 | Nintendo DS Lite
DS Lite game card won't "click" into slot
Slightly push once. If too fast come out.
If still, back to nintendo
Apr 16, 2009 | Nintendo DS Lite Console
Nintedo ds lite
Yes it can can cost anywhere from $20 up
from any Repair shop
Sep 06, 2008 | Nintendo DS Lite Console
Nintendo ds lite - son putgame cartridge in wrong way and has bent a pin on the console - fixable or not?
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but it is too impractical for most people to attempt a repair to this part.
However, if you are savvy enough to attempt the repair of the damaged pins on your DS Lite, here are my recommendations:
1) Cut a flap in the slot-1 port cover and straighten pins.
2) Replace the main board.
3) Remove the slot-1 port cover and straighten pins.
4) Remove the damaged pins from the slot-1 port and straighten.
5) Replace the slot-1 port.
All of these recommendations require disassembling the DS Lite using a specialized triwing (or Y) screwdriver and a lot of patience. The following video will help in disassembly: http://www.youtube.com/watch?v=HQlTpTLUyFQ.
Recommendations 3 to 5 all require solder work. Recommendation 3 requires solder work for 4 solder joints, 1 at each corner. Recommendation 4 requires solder work for up to 17 solder joints, one for each damaged pin. Recommendation 5 requires solder work for all 21 solder joints
Aug 27, 2008 | Nintendo DS Lite
Nintendo ds lite won't read card
had this problem, i looked into where the game goes and one of the little metal teeth was bent, so i took a long toothpick and gently pushed it back over now it works fine. Be careful that you dont break it off though.
Feb 08, 2008 | Nintendo DS Lite Console
DS recognises game but won't play
check the connectors inside cartridge slot inside ds, verify if they are all aligned ( | | | | | ).
if any contact is bend, you must align it, also check for dirt or rust inside slot.
sometimes you will need to clean contacts inside. you must buy a cleaning kit to do it.
Dec 02, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
