I was given a Rio Carbon as it was not working. I have other Rio products. Anyway. When I first plugged the Carbon into the USB port of my computer, the battery charge display showed for about a minute, then the display showed the Rio Logo. So far so good. No lights come on at this point. Then, the display changes to the word "Updater". I have run a variety of firmware programs that are for the carbon (found them on the Rio site and others.) and they do see the Carbon, but display the firmware as version 0.0. A few times the program has returned that the update did not work and does not state a reason, but most of the time it says it was successful. Then, the Carbon reboots and does the same thing as listed above. I've left it plugged into the USB port over night and tried again, and still get only the Updater sign, but no longer see the battery charge display.
I've booted while holding down the reset button and power buttons at the same time. Still no luck.
When I go into Windows XP Explorer, I can see that the Carbon is there, but when I click on it Windows asks me to "Insert a disc into Drive F", which would be the next drive.
Is this Carbon better off as a door wedge than attempting to make it work? I'm willing to take it apart if something would help such as perhaps a loose connection.
-   ok i have had this rio for quite sometime now and i had another rio that i destroyed because of the upgrader. i am going to try this whacking thing and i swear if it doesnt work im gonna cry.
-   zooboo
May 30, 2008
-   Rio Carbon have had for a while and love it. Dropped it the other day and now it just show "UPFRADER". Reloaded firmware and the same thing. I am so pissed at myself this thing has been my BEST MATE!!!. The software says that it is in Recovery Mode. Is there no fix for this?
-   on the screen of my mp3 player appears 'upgrader'. i tried to fix the problem by using a variety of firmware from the official site but it doesn't work.my player is still in recovery mode. please help me. thanks-   buburuza
Dec 20, 2007
-   I have had similar problems with my Rio Carbon to other people Here are my symptoms and my solution.
- When it started it would go to the rio screen, briefly show "New Content" and them stop. It would repeat this indefinately.
- Or sometimes I would get the battery flashing (which I think indicates low on power) - but I had left it charging for several hours
- Or when connected to a computer the screen would mostly show idle but sometimes reading or writing
- Or Particularly after trying a reset the screen would show upgrader
- The rio music manager reported "In recovery mode"
- Windows explorer reported something else (sorry I forget now)
I tired many of the suggestions reported here. Various resets and bashing the Carbon - these might have helped
My final solution was. I connected to a computer with USB 2.0 (I don't no if this was significant but I thought the extra power or something might help)
I reformatted the Carbon. I had to wait quite some time has I right mouse button clicked on the icon for the carbon and selected format. BUt my patients was work it as I was eventually able to reformat - now to put my music back!
-   Guest
Dec 05, 2007
-   stuck in upgrader no drive found but shows up as drive-   Guest
well i own one too and thats probly the hard drive being stuck...just smack it against something hard , like sorta bump the rubber armor against the heel of your hand or a countertop...worked good for me...ya have to do it a few times...dont worry rio is defunct so theres really no warranty to think of anywayz
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on May 04, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I can't believe it, but Solution #2 works! After hours of trying to reload stuff, I gave it just one whack & hey presto!! Brilliant!
Press with a niddle on the reset hole, and after the message is gone try to turn it on. You should get an empty battery image, then recharge.
Was this helpful?
Yes
No
Solution #5
posted on Mar 17, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i've had the same problem with that damn UPGRADER but I JUST FIXED MINE!!!!!!!!!!!!!. i don't know if this will work for all of them but it's worth a try.
i pushed and held both the poswer button and the joystick down and held it till Rio showed then the words Cali appeared underneath then the back light lit up. after that i let go of both buttons and BOOM! i had my player back!
i wish you all the best with getting it to work
Solution #6
posted on Dec 14, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
wow thank you everyone. I tore apart my apartment trying to find the rio CD that came with the player, didn't find it, googled rio upgrader, and thankfully the first result was this one. I share in the amazement that hitting the player works like a charm. I just tapped the bottom rubber side on the desk a couple of times and it snapped out of its coma.
Solution #7
posted on Dec 18, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
To think I actually have been resisting the urge to beat on this thing for two days. One decent whack fixed it.
Hi. I alternated hitting reset at different points and trying to read the Carbon. Eventually, the computer stopped asking me to insert a disk. I formatted it and upgraded it, but it still isn't working 100%. I think this is the light at the end of the tunnel!
Was this helpful?
Yes
No
Solution #12
posted on Jun 06, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I tell you what - whacking it works a treat! Bloody thing was about to get binned til I tried that. Thanks all who suggested it.
For me I just kept trying the update and smacking it around in different directions. The update finally was able to finish after I hit it on the screen side.
Was this helpful?
Yes
No
Solution #18
posted on May 14, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution number 3 (the one about hitting it on something hard) amazingly works great!!
Running WinXP Pro SP3 - Rio Carbon shows up as hardware under Windows Portable Devices but not under...
(More)
Running WinXP Pro SP3 - Rio Carbon shows up as hardware under Windows Portable Devices but not under USB Controllers. Also does not appear as a hard disk or portable device in Control Panel or Explorer. How can I get the PC to recognize and work with it?
