Before my machine completely stopped turning on, I would have to press the power button several times for it to boot? Has any body else had this problem? Can it be fixed?
-   I think I have same problem. It turned on about half the time. Now it doesn't turn on at all. When I press the power button the light turns and the hard drive makes a small noise as if it has power. The floppy drive is also active but doesn't read anything.
-   Gerelki
Apr 29, 2009
-   does not turn on, or only on once every dozens of tries. Probably because of overheated (not repairable) motherboard. Fairly common in this model.
-   Guest
Dec 08, 2008
-   it happens the same with my lapt. I'll be looking for a solution and if I find I'll post it here-   kikosan
yes, you need a new motherboard. hp lappy's have been having serious issues with these problems. my suggestions is look for a service that does board work in your area to reflow or repair the motherboard. ebay has tons of people who offer this service.
My Pesario F700 shows a blank screen when turned on. It is making noise so I know its running. If I...
(More)
My Pesario F700 shows a blank screen when turned on. It is making noise so I know its running. If I turn it off or sometimes take out the battery turn it back on then it will work. Why is it doing this?
