Question about Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Karaoke Player
Words "roll" on Screen
I have tried different monitors so it seems to be my box - It rolls the words on any CD, much like old TVs used to do if the horizontal hold needed adjustment
  • dinkel43 Oct 21, 2008
    I have the same problem, but the player has worked for a year, on this same tv, it just all of the sudden bgeanrolling, I attempted 3 different tv's and the probelm was the same on all, I also changed out the Video cable and it still has the rolling problem
    Problem Solver:
  • 6 Answers
Sir, where did you purchase your player?i think theres a problem with your COLOR SYSTEM SETTING...the color system(REGION NUMBER) of your player must be mATCh with your tv monitor ...TRY TO set it using remote control of your dvd player...and try diff color system setting....post the result.ty eg:NTSC PAL =THESE ARE THE COLOR SYSTEM SECAM
Posted on Apr 24, 2007
SOURCE:
How do I play a split track cd without the words coming out monitors I want music only
try playing it using a different player, or turning off lyrics in the settings menu of your player :-)
Dec 03, 2014 | Music
Yes please help us why it looks like so small
If you are referring to the desktop and the icons being small, just change the screen resolution. Right click your desktop and choose Properties or Screen Resolution. Just decrese the resolution if you want the icons to get bigger. Otherwise, let me know what is seem to be small.
Apr 30, 2011 | Computers & Internet
My printer has stopped printing the letters onto the dvd properly
1. Remove lid/top
2. Move blue lever left or right to unlock ribbon roll
3. Loosen ribbon or tighten as needed -
NOTES: If ribbon roll is too tight it will show wrinkles; it should look smooth if positioned correctly; if too tight it will not print portions of some letters; keep re-positioning if this does not work after first try.
4. Use flat-head screw driver to adjust front uptake (used) ribbon-roll as needed to make it smooth too. Lift out & re-position, if you need to.
THIS WORKED FOR ME but I had to re-do my re-positioning of both rolls several times before it began printing 100% of letters again. 4bb240d8-5e9d-4611-9ca4-33b5883e40b9.jpg 5a5b4381-7ee8-480f-943e-041aa738011d.jpg c86d59ae-1b7e-4755-b895-08007064e847.jpg Journal Kentucky Lexington Monitor www jklm us
May 20, 2010 | Rimage Perfect Image Prism Thermal Printer
The screen keeps rolling
I had the same problem.. had to change my video cord that goes from player to TV
Mar 25, 2009 | JVC XL-MV303 CD Player
Screen rolls constantly from top to bottom
my brother in law and I was a bar the other day and theres was doing the same........so was his thats why we was talking about it....we sovled he was toldthe cables was to close together try putting them apart more or buy more thicker ones....or you can can tape black tape around them.....or this going sound funny but try putting a rubber grounded house around them........another words the cablees are to close to each other and they are interfering with each other
Mar 16, 2009 | Televison & Video
Rolling Waterfall Effect going up my westinghouse LCD monitor
try moving the monitors.
it could be feedback signal.
also try different leads or without switch.
you will then be able to narrow down the problem to one component.
Feb 25, 2009 | Acer AL1711 17" LCD Monitor
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Picture rolls on the screen
your tv had no problem, use the remote of your karaoke machine and press the system. your karaoke machine was set on PAL change it to NTEC or press N/P
Sep 27, 2008 | Orion1934 19" TV
Screen rolls
I'm writing to you on a screen that is rolling and sometimes flickering right now. I've tried 3 different screens on the same outlet, and they all have the same problem.
1. If you have any speakers near your monitor, try moving them away, this might help because they might not be shielded enough.
2. Try another screen, if the problem persists, it may be your power outlet.
3. If you don't want to spend money on a new screen, spend some time looking for a 3-prong grounding adapter.
I used the 3-prong grounding adapter, those little adapters that plug into the wall using 2 prongs, and then you can plug a 3 prong appliance into them on the other site, and it helped make the rolls not appear as often, and not as dark.
I think it is something with my power or the plug I am using.
Hope this may have helped a tiny bit
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Karaoke Player Logo
145 people viewed this question
Top Cavs Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Cavs Audio Player and Recorder Expert? Answer questions, earn points and help others
