Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Blowing the gfi outlets and is without power
Tried industrial extention cords to the garage, and it tripped those too.
  • 26 Answers
YOU CANT PLUG REFRIGERATERS INTO GFI'S BECAUSE OF THE COMPRESSER VARIYS THE AMPS UP AND DOWN SO IT TRIPS THE GFI.
Posted on Jan 27, 2009
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
No power to wall unit
Have you tried plugging anything else in?
Also does the cord have a GFI breaker on it, or is the outlet a GFI outlet, if those are tripped it will keep power from going to the unit. If they tripped more then likely they got wet, or there is a short circuit.
Otherwise if all that is good circuit breaker would be next to check.
Aug 19, 2013 | Fujitsu Heating & Cooling
Ge side by side refrigerator trips GFI
Try an extension cord to get it off the GFI outlet .
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
The Ebara EPPD 3MS1 pump will trip the GFI breaker on the outlet
Will the Gound fault socket (outlet) support the current rating of the pump
is the outlet wired correctly where the return wire is in the correct spot and the high and ground is correct not switched around?
Does the pump run in a standard outlet?
Test it with a heavy duty extention cord if no standard outlet socket is nearby?
Is the pump shaft dragging putting an un necessary load on the motor?
Aug 02, 2009 | Ebara EPPD-3MS1 PRO-DRAINER Manual Sump...
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Hotpoint refrig 21 cf over and under
Of course it can be plugged into a GFI outlet. Sounds like you have a compressor problem.
Nov 24, 2008 | Hotpoint HSS25GFP Side by Side...
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Sep 07, 2006 | Whirlpool AD50USL Dehumidifier
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
105 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
