Question about Motorola Mobility V170
No incoming calls
My phone quit incoming calls. When a call is received it goes directly to voicemail, does not ring. The phone turns itself on and off and several times a day the screen message says "Emergency Only" It has not been dunked, dropped, or damaged. I've had it for 11 months using Tracfone prepaid. Any suggestions, other than giving it a dirt nap? The battery has a full charge,there is "units" left in the airtime tank, expiration date isn't until May. I've tried asking Tracfone, but they have not replied.
  • 74 Answers
Dear disable this function from voice mail setting will ok if u not find make master reset that is avail able in setting.
Posted on Mar 27, 2007
SOURCE:
Mobile phone,all incoming calls go to voicemail,without ringing
you did not provided what brand, model and year, therefore you need to read your manual...
you need to find in your setup section and enable calls, setup as to re-direct to voicemail after say 5 rings, enable ring.
unfortunately without model and year - more detailed directions cannot be provided...
Feb 08, 2015 | Cell Phones
I can call out on my cell phone..BUT it won't ring
The ring signal may be turned off and incoming calls go directly to voicemail
Sep 12, 2012 | Samsung Cell Phones
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
My lg 410g phone does not ring when there's incoming call but goes directly to voicemail
the reason the phone automatically goes to voice mail is simply because the phone has sim card has been set to do so.
The solution is for you to deactivate the voicemail.
That is when you will be able to receive your call properly.
To deactivate the voicemail, all you have to do is to dial ##002# and send.
it will deactivate the voicemail of your phone and you will be able to receive your calls aswell as your phone will also start to ring out.
take care
Jun 18, 2010 | LG Cell Phones
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
HTTC 6800 Not receiving calls in sleep mode
You want to make sure your callforwarding is on. Sometimes when you select sleep mode, the calls will divert directly to Voicemail. Plus, ensure you have signal. Without signal, by default the calls go directily to voicemail. We won't wanna miss a call here. You can follow these steps here. start
settings
phone
services
call forwarding
get settings (wait for a while)
forward all incoming phone calls (check the box)
OK
OK
Exit
In the option to forward calls, there should be an option for the amount of seconds the phone RINGS prior to forwarding directly to voicemail.
IF your HTC device doesn't have the option for voicemail, and your calls are routed else where, contact your carrier for the voicemail number. This is very important!
Cheers!
Jan 30, 2009 | HTC PPC-6800 Smartphone
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
Incoming calls
Messaging then Voicemail this is where the settings are stored you can disabl all then your phone wll just keep rining or change ringing time
Jun 22, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
My new Razor will not ring
do a master reset and clear of the phone
May 13, 2008 | Motorola Mobility RAZR V3
Motorola Mobility V170 Logo
455 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
