Compaq Presario 700 470024-192 Notebook Logo
Posted on Dec 08, 2008
Sound driver problem
My laptop show message new modem audio device found
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
19
Points
I am not find sound drivers for windows xp2 service pack
3answers
After formating my laptop computer shows no sound card. can`t fix it. help please
you might have to uninstall then reinstall both the driver and the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
I cant get any sound from my laptop audio speaker....the high definiyion modem audio driver is not installed...
The latest drivers for your device and operating system can be found here-
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=96120&lc=en&dlc=en&cc=uk
Download, install and restart your computer.
If the problem persists reply with any error messages or additional information.
//javaftper
I have reinstalled Windows xp on my Laptop 6400 inspiron and now I have no audio. I have check Control Panel and it says no audio device is installed. I have tried to download Sigmatel from the Dell...
i believe the audio device for this model is located on the modem bus.
if you install the modem driver first then the machine should display the "found new hardware" wizard. DONT USE THIS.
ignore the wizard and proceed with the sound driver install then reboot the machine.
that should work providing you have installed the drivers in the correct order
1helpful
I could not install drivers for my compaq presario v6500 laptop. now this is intalled with windows xp..when i go to install audio driver directly it shows message like ''media device not found''.. is there...
if u 1st install the driver but not working,remove the old audio driver then reboot the PC/unit then after reboot try again to install the sound driver located from the folder of CD.Now if see running sound exe. just make a free run at self if u see message say restart do it.Good Luck and Have a Nice Day...^_^
1helpful
Driver installation problem
right click my computer>properties>device manager>hardware>look for audio device and if there is a yellow interrogation near it then there may be a problem and you will need to try to install it manually.Which means something like disable and re-enable and maybe update driver..Thats how I wll troubleshoot this...
WHENEVER I TRIED TO INSTALL AUDIO DRIVER IN MY COMPAQ NX7300 A MESSAGE APPEARS WHICH SAYS THAT "HDA AUDIO DRIVER WAS NOT FOUND WHICH IS REQUIRED" AND THAT INSTALATION STOPS HOW SHOULD I INSTALL AUDIO...
go to your control panel click system then go to hardware manger devices look for sound if you see anything under sound click it and update driver if this dont fix it then remove the device from the list and go to add new hardware and try againg some time and old drive will cause the new drive to not install allway say no to seach for driver point computer to the location of the driver like c: or d: make sure the computer can find the driver to install
4helpful
3answers
Driver for modem device on high definition audio bus
please download the drivers from this site given below.
http://www.zyxware.com/articles/2008/10/07/compaq-presario-cq40-108tu-laptop-drivers-for-windows-xp
Do rate this solution
3helpful
2answers
I have hp 530, i need audio drivers plz help me i'm relly in need of it.i Instruct xp, after Instructions i can't fine audio
here u go all drivers pls rate me FIXYA
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3375995&lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375953&taskId=135
12helpful
4answers
9helpful
9answers
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
