HP M1522nf printer, shows "scanner error 5"
Turning off and then on again does not solve problem, neither does restarting the computer.
Even restarting when the printer is disconnected from the computer, it will not copy, just make a lot of noise, flash the scanner light and then display "scanner error 5"
  • 7 more comments
  • Anonymous Dec 10, 2008
    Same problem, any idea?
  • electronic_g Dec 15, 2008
    I have the same problem. I will contact to HP. Now I will wait the answer
  • Randall001 Dec 27, 2008
    flashes scanner light, jerks scanner across platen, makes grating noise
  • Anonymous Jan 11, 2009
    Same problem. Turning off and on doesn't fix. Makes a grating noise.
  • Anonymous Jan 14, 2009
    same problem; orange exclamation point blinks, too. turning off, then on, does nothing.
  • tanco Jan 31, 2009
    HELP!!! DOESN'T SCAN ON MY MAC!
  • Mavidwana Apr 18, 2009
    The scanning arm goes very slowly with a funny noise. The display shows error 5
  • Anonymous Apr 27, 2009
    M1522nf printer, shows "scanner error 5 nothing works to rectify
  • Somsak Tantong
    Somsak Tantong Dec 18, 2009
    Where can you buy the stepper motor of the len scanner? I just opened up the cover and check. It is Mitsumi M35sp-9t
I have the same problem, could you pl let me know where can I get the stepper motor?
Posted on Mar 07, 2010
  • 72 Answers
I had to contact support, but all they do is make sure you try connecting the printer to the wall outlet, then a different wall outlet, then reset to factory defaults. After that didn't work, they submitted an replacement order.
Hope this helps!
Posted on Mar 27, 2009
English: Error scanner 5 try to change the stepper motor of the len scanner, this fixed it my problem.
Español: Error de escaner 5 reemplaza el motor que mueve el lente del escaner, es un motor de paso, puede estar averiado; esto funciono en mi caso.
Posted on Dec 15, 2009
I know this post are from a while back but Call HP at 1-800-633-3600. This a known issue on this printer and several others and they will replace the scanner assembly and formatter for free.
Posted on Nov 22, 2010
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M1522
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
Contact Hewlett Packard for possible Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Hp laserjet m1522nf. when you print it states scanner error 5 turn off then on
See my tips section for the solution to this. This error is covered by HP and they will repair at no charge for almost all M1522's ever made.
Apr 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
Its showing scanner error 8 and 5
Hello, this indicates aproblem with the copier scanner assembly.
For more information follow the posted link.
Scanner Error 5 CLICKHERE
Feb 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hp laserjet m1522nf
Copy function was not working, says "device is busy". Message appeared on the printer screen is:"scanner error 5, turn off then on". This was done several times and message still appeared. I called 866-625-1176 and was connected with HP Technical Support and after 20 - 25 minutes of diagnostics, the technician informed me that they were sending me a new printer at no charge. I assume this meant that HP is aware of the defect and has no solution other than to replace it. The printer was only 6 months old.
Sep 05, 2008 | Office Equipment & Supplies
8,396 people viewed this question
jasbo
jasbo
