Question about RCA Video Cameras
RCA VHS CAMCORDER
I have a RCA #540 camcorder that needs repair, experts tell me it will cost about $250 to repair it but it's not worth it. I have not found a digital that has the zoom or the clearity of this camcorder. I have owned several and looked at several more in the $250-$500 price range. Why is the old technology better and can I find a digital as good
  • 4,234 Answers
Let us attack this from a different perspective. What is the problem with the camcorder? Typical labor rates will be in the $150 range, so you are looking at that much for the repair without parts. Please update this with a problem description and I'll try to provide you with what needs to be done to fix it.
Thanks,
Dan
Posted on Dec 08, 2008
I have a jvc Compaq vhs camcorder that is about 12 years old. it turns on but will not play the cassettes so it needs repairing. can anyone help or recommend a repairer?
My suggestion would be to use a VHS player and convert your existing tapes to disc through your computer and then buy a new camcorder that uses SD cards, They are dirt cheap and it would probably be cheaper than the cost of repair.
Dec 31, 2014 | JVC Video Cameras
Rca cc540 video vhs camcorder manual
I have an owner's manual for an RCA CC412/540/542. This is not a schematic; just an owner's manual. Almost new; probably used one time.
Apr 04, 2013 | Video Cameras
The camera will not record any more and i can't locate a place in ontario canada that can repair it since rca is not doing repairs.
It's not what you want to hear, but this camera is not worth fixing. You can get a much better HD digital one now for less money than this one cost, and maybe less than it would cost to repair. Let it go.
Nov 19, 2010 | RCA PROV702C VHS-C Analog Camcorder
Need Manual for RCA VHS Camcorder Model No. CC 285
TRY THIS .GOOGLE Manual for RCA VHS Camcorder Model No. CC 285
MAY NEED A BIT OF SEARHING
IF YOU FIND A PDF VERSION,DOWNLOAD IT,AND BURN TO DISC
KEEP IT SAFE RUN IT ON COMPUTER OR PRINT IT OFF
Feb 15, 2010 | RCA Video Cameras
MY RCA DRC 8320n DVD Recorder/VCR Combo will not accept tapes. DVD works fine. RCA help line is a joke. I will never buy another RCA product.
Yah, you're going to be taking that in for repair. I worked for couple of years at RCA / Sony / Panasonic / ... and 60 more names - service center. When a VHS Cassette loading mechanism doesn't work - it probably needs loading motor or loading gear, something repaired. At the cost of DVD and VHS combos these days I'd call it Not Worth Repair (NWR) out of the starting gate. At least $50 an hour, at least 2 hours ... that's beyond the cost of a new one.
Nov 22, 2009 | RCA DRC8320 DVD Recorder/VCR
My Sanyo 34cm TV has no sound and no picture - How much it cost to repair ?
yes this can be repaired !
the cost of these type of repairs run around $300
i would say its worh it when it will last a long time after the repair!
check around to see who might have the better deal in repairing this tv
most of the time they will tell you that it needs to be tested to determine the cost but if they have done it enough then they should be able to give you an approximate estimate
Oct 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TAPE WILL NOT EJECT BLEEPING AND FLASHING C;32;11
You need your CAM into Sony or service center Sony to repair it the error code is indicated the LS chassis assembly faulty or loading motor faulty it require a lot of work mechanis and electronics it may not worth to repair it. It would cost between $150 to $250 in AUS
Cheers
Oct 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
RCA CC617
probably the lcd screen is broken (the one that you can see through the veiw finder) if this is the case it is not reasonably fixable. Otherwise it may be a connection that is broken and it is not getting any feed. If you give it a little tap and it comes to life breifly, this is probably the case. You can take it to a small electronics repair shop and they will let you know if its worth fixing or just using as is.
Jul 08, 2007 | RCA CC617 VHS-C Analog Camcorder
Video Cameras Logo
226 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
