Dubbing through AV jack, with or without S Video cable, from DVD or VHS players to Camera
Dear Sirs,
I hope you can help me.
I have had my Camera NSTC ZR90 for a couple of years now and have been extremely pleased with it.
I have dubbed scenes before, for downloading to my computer to edit the same, with no problem.
However, when I try dubbing now there is a Black Border around the picture in the LCD Screen which transfers to my editing software causing the image to only appear in the middle of the screen. My editing software works fine with older footage I have dubbed.
I have looked through the Camera Menu and the Manual extensively and can find no reference to a Black Border appearing during dubbing.
The camera records very well to tape with no Black border.
I have tried cleaning the Video Heads, with the Canon Head cleaner with no effect.
To sum up, this Black Border only appears when I am dubbibg, whether I use an S Video cable or not.
I trust that you can assist me in this matter.
Yours Sincerely,
Jeffery Pocock.
Re: Dubbing through AV jack, with or without S Video...
Jeffrey,
Please check in the user menu to see if the camera is in "cinema" mode. This can also be referred to as 16:9 or 4:3 aspect ratio, you would want to select the 4:3 option. If 16:9 is selected, the 1394 and composite outputs will be affected.
Hope this helps my friend.
Joe Weibel
customelectronics.org
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
1. Set up with a new blank DVD. 2. Insert VHS and adjust to the beginning of your recording. 3. Use the DUBBING button on your remote: you can adjust video quality (2 hours or 4 hours play) at this point. 4. RTFM for use of the PAUSE and DUBBING buttons to skip over commercials etc.
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Most DVD players today have only RCA jacks for video and audio outputs, and don't have RF (channel 3 or 4) outputs. If your TV doesn't have AV input jacks (either too old or just not supplied on your model) you can't connect the DVD player directly. You'll need to get an RF converter to make the connection.
An RF converter costs about $15 and you'll find them where you can buy TVs. The converter takes the video and audio signals from the DVD player and creates a channel 3 or 4 output signal to your TV. If you don't have the cables already, make sure to get them too. You need a "dubbing cable" (RCA plugs on the ends, usually color-coded red, white and yellow) to connect the DVD player to the converter input jacks and an RF cable with "F connectors" on the ends for the output to the TV. Often the dubbing cable comes with a new DVD player, and the RF cable with the RF converter.
If this takes care of your connection troubles, please take a moment to give my solution a good rating. If I've missed something and can be of more help, please post a followup comment.
check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
diagonal roll often indicates a loose ground or a defective cable/RCA connector;
verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
I have the same problem. I saw a solution that said I needed to set my cable to a non-premium channel like NBC, ABC, PBS, CSPAN in order to allow the dubbing to occur without the +VR problem. At first, I thought it was a stupid solution; but guess what, It worked. I just set my cable box to from HBO to CSPAN,restarted the dubbing from VCR to DVD and it worked. Now the question is: Why do I have to change the channel when I'm dubbing from VCR to DVD?
This worked for me..still trying to figure out why it worked???
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
