Question about Panasonic AJ-D230H DV/Mini DV VCR
Tape format playback for AJ-D250
Can the Panasonic AJ-D250 mini deck be set to play a regular DV186 tape? DVC Pro tapes are no porblem, but I did not know if the menu setting could be changed to play DV. The deck's manual is with our engineers, and they are out today.
  • 221 Answers
Menu item 107 can be used to select dv playback
Posted on Dec 10, 2008
Where does USB from DVC Pro deck to into Mac hard drive?
AJ-D230H doesn't have a USB connection. A firewire interface is an option, but they're very hard to find; have been discontinued by Panasonic.
Feb 13, 2010 | Panasonic AJ-D230H DV/Mini DV VCR
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
My Panasonic AJD230 is spitting out some but not all, tapes
The capacitors are old and need replacing. And what I mean by caps is ALL the caps. These decks are known for failing capacitors - even if the deck hasn't logged much play/record time - time is not kind to them. Panasonic have ready made capacitor sets for the decks and even though you might be able to fix your transport problems by replacing only a portion of them, it's advised they all get done at once. That's between 10-20 hours for an experienced tech and it will cost you. What can you do?
Oct 26, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Tape deck no longer plays large DVCpro tapes
the tape compartment elevator has switch senors that tell the machine what size tape is in..
does the tape load all the way.. you need to tell us
is there an error code ?
either the sensor or the reel motors the feed and uptake the tape,,
they ride on rails and slide into position to accomodate the tape side they could be having trouble moving, dirty, broken actuator
Apr 07, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
It acts like the heads are dirty but they have been cleaned
4000 hours is not bad for a clean machine that is fresh
they reset the drum and capstan run time meters when the machine is serviced: so you can have circuit boards that are getting tired.. The boards have lots of Surface Mount Electrolytic Can Capacitors... the parts used are rated for 3000 hours of use at 100 deg Celcius.. they last longer as the temperature goes down..
they have a chemical inside that dries up...
so the machine may need overhaul.
but an old tape can cause this, a worn & dirty pinch roller can cause this also...
Mar 11, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
E-62 error on AJ-D250 points to a cassette housing problem. either replace the cassette housing or have it rebuilt (replace gears on the sides that raise and lower the cassette). "replace belts" won't work - the AJ-D250 doesn't have any belts.
Oct 14, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
DVC recorder
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
May 08, 2008 | Panasonic AG-DVC200 DV Digital Camcorder
Mini DVC Tape
Hi Luigi, Have you tried playing the tapes on a different camcoder we would want to start by a process of eleimination.
Apr 20, 2007 | Fuji DVC-M60 Mini DV Tape
Panasonic AJ-D230H DV/Mini DV VCR Logo
147 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
