Question about Sanyo DS31520 31" TV
Remote control i just want to know if you can order a nother remote control model dp42848. and if so how much. yvonne
  • 1,199 Answers
Sears . com should be able to get it for you no problem!
Posted on Dec 08, 2008
How do I get the DP42848 to accept the HDMI inputs?
You have to connect the TV to any device; which have HDMI output; using an HDMI cable in between, and to select the input of the TV to HDMI, using its remote control's input selector button.
The HDMI cable will look like this.
Sep 25, 2014 | Sanyo DP42848 LCD TV
Picture on a Sanyo dp42848
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. .
Sep 08, 2014 | Sanyo DP26648A DP32648 DP37649 DP42848...
Hi i`m looking for a remote for my sansui sv-epd-4240bp. I lost it. And want to know if there`s a web site where i can order a nother one.
I would check Ebay for a replacement. Any remote that is labeled for sale as a "Universal" remote should work too - you don't need the brand's specific remote.
Mar 06, 2011 | Televison & Video
I lost the manual to my tv remote and i need the remote code
go to the website the name of ur remote Brand name and model number.U get some help.
Aug 15, 2009 | Televison & Video
Picture is slightly too large for our sanyo DP42848
This is a problem with the aspect ratio setting. Usually found in the setup section. You can use your owners manual to locate the setup section and find the procedure for changing the aspect ratio settings.You should be able to do with the remote control or the buttons on the television. You can call the Sanyo customer support at this telephone number. 1-800-877-5032. Give them the model number of your television and they will be able to help you . I hope this information has helped you with your problem.
May 22, 2009 | Sanyo Televison & Video
Cannot get in the menu to set cable channels with remote control is there a nother way
if the tv has its own menu ,you can try it.or you can open up your remote and clean it using alcohol with cotton or soft cloth.remove the batteries first.let it dry.also, clean the rubber keys over and under.check for cracks in the rubber keys if you can.if not ,you'll need another remote for your tv.
May 14, 2009 | Panasonic DBVSQ-W0044 Remote Control
Programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Apr 22, 2009 | Sanyo DP42848 LCD TV
Not functioning on my tv sensor
need nmore info then that. are u saying that the remote control is not working with the tv or are u saying that the controls on the set is not working . ok lets say the remote is not working 99 times the problem is the remote control unit. the best way to find out is. if your tv is a newone 1 -2 years old u could take the remote to best buy and see if it will work on a nother tv set there. if not it is your remote problem solved.if it does work then i could be the sensor but u need a scope to see the rf signal from the sensor i have only change 2 sensers in my 30 years working in electronice service field. let me know marty
Oct 13, 2008 | Televison & Video
Sanyo DS31520 31" TV Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
