Question about Sylvania 6413TD 13" TV
How to set up
I faced aproblem in my sylvania 6413 td 13" tv, that I cant use its av input port. I sure that I connected the AV cable correct. but I dont know how to change its mode to AV. with my best wishes khaldun
2 Suggested Answers
SOURCE: 6419ctb how to use av inputs
i needs the codes for the tv please
Posted on Mar 31, 2008
SOURCE: how can i put it on AV mode?
you will have to call the number on the back of the TV. There you can by a remote. I had the same problem.
Posted on Jan 25, 2009
0 characters
1 Points
Can i use a dvd player with my duraband tv
If there is AV in socket, either at the front panel or rear side of the TV, you can surely use it with a DVD player. Just connect the tV with DVD player using an AV cord [can be bought from electronic spare part selling shops at your town]; and select the input to TV to AV. Picture of AV cable attached.
May 18, 2012 | Durabrand DWT1304 13" TV
I have a Daewoo DTQ-13Z5SC trying to run sega genesis on it, how do I get the av to work? don't have manual since I bought tv second hand at a thrift store
If the game box have AV out on it, you can connect it to tVs AV in by using an AV connector wire.This is the pircure of the AV cable that should connected in between TV and game box. You must select the input to TV as AV.3_4_2012_1_36_06_pm.jpg
Mar 04, 2012 | Daewoo DTQ-13Z5SC 13" TV
I can hear the tv but no picture.. i remove the red, yellow, and white cord from the back of the tv to dust...pls help.. Apex tv brand
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the equipment for example DVD is connected to the TV.
* Plug the RCA cables(red,yellow,white cord) to the designated ports.
* Grab your Apex TV remote and attempt to cycle through the video inputs by hitting the "Input" button at the top of the remote multiple times.
* If you have used a DVD player or similar external device recently, you may have neglected to switch the video input back to the one assigned to your TV programming.
* Devices such as DVD players often reside on the AV 1 or AV 2 video input, and failure to switch back off of one of these will result in a dark, soundless screen when attempting to view cable or satellite television.
* Cycle through the inputs until you land on your cable/satellite input once more, which should result in an immediate restoration of picture and sound.
* If it does not, approach your Apex TV and look over the A/V cable connections. The A/V cable has two sets of prongs, one on either of its ends. Each prong is either red, yellow and white, and plugs into corresponding A/V ports on the back of the Apex TV and the back of your cable or satellite box. Make sure the ports and prongs are color-corresponding and have not been switched up.
Thank you for using FixYa. Keep me posted. :
Mar 12, 2011 | Standard (CRT) Televisions
just do these connect AV output from your dvd player to AV input in your TV.
Jun 09, 2009 | RCA 27F650T 27" TV
Tv magnovox tv
firstly try that tv to a different tv
if this works
then check your tv av connections in side tv
also check cables continuity
if this fails buy a AV/ RF converter, have your AV be connected to a converter, and let your output be RF feed to a tv, RF input, so instead of using AV on your tv you will be using RFchannel mode
Mar 16, 2009 | Philips Magnavox 27MS343S 27" TV
Zenith SMS1943S made 1995 Need code to switch to dvd status
1) check the RCA cable connection from your DVD to TV screen.
make sure that each cable is in the right place (for DVD player yellow cable = video/ red and white cable = audio) (TV screen: yellow cable = video IN /white and red = audio IN
2) from your TV screen locate and check for A/V IN socket. it's either at the back/front or side of the screen.
note: some of TV screen does have 2 A/V inputs
3) Facing the front of your TV screen, locate a button indicating "A/V" or "AV" or a box picture having a forward arrow inside.
note: if you locate the said button and your screen have 2 A/V inputs press the said button until the right input where you connect your dvd cable been set.
Jan 17, 2009 | Zenith C13A05LG 13" TV
Can't get Leapfrog to work with Orion (13") tv
Use the TV/AV button on the remote to turn on the "ports".
Oct 13, 2008 | Orion Standard (CRT) Televisions
29" crt tv video and sound problem
Is it possible that the input to the TV is still good including cables and cable box or anything? If another TV works from the same input then it may be the TV settings like AV/video rather than TV channels. Check all this out. I hope it is something simple as that. Good Luck.
Sep 22, 2008 | JVC AV-36150 36" TV
Av black and white
please don't take this as me doubting your intelligence, but are you sure your wires are good? sometimes they can become worn out inside of the protective rubber, and partially fail.
Also, how old is the TV? I just got one (for free so i can't complain) from a friend that will start in color on av and then turn to black and white because something inside of it went bad..
May 09, 2008 | Spectra Logic Hello Kitty 13" TV
Please Help Me
You have accidentally switched the set to AV external input. Use the remote & on screen menu to switch back to TV or cable input.
Jul 15, 2007 | Durabrand DWT1304 13" TV
Sylvania 6413TD 13" TV Logo
Top Sylvania Standard (CRT) Televisions Experts
Kenneth Walker
Are you a Sylvania Standard (CRT) Television Expert? Answer questions, earn points and help others
