Question about Nikon D40x Digital Camera
No autofocus My Nikon D40X does not autofocus. On manual, everything works fine. On autofocus, the shutter will only open if focus is met. Thanks, Kyle
  • VIC001 Feb 17, 2009
    just purchased a used in almost new condition d40x digital slr. It came with the 18-55mm AF-S Nikkor lens. At first everything worked fine. Recently, I tried to take pictures and the auto focus wont work. On pressing the shutter release it won't work. When I switch the lens to manual, everything works. I'll try with another lens.
We tried the same lens on another Nikon (D90) and auto focus did not work.
We mounted a new set of lens on the original D40x, and it worked.
Turns out the 2 year Nikon lens (18mm-135mm) was bad. Nikon lens have a 5 year warrantee. The lens will be sent back to Nikon with no service or shipping charge.
Posted on Dec 09, 2008
My Nikon D40x will not always take a picture when I push the shutter and will not focus whats wrong with it?
I have the same problem and I make this: take out the zoom lens from the body and put it again. The auto-focus comes back. Another my solution: Push autofocus buton to M (manual) and back to A (auto). Then sometimes starts again to work autofocus. But still I know it is not final solution...
Feb 12, 2013 | Nikon D40x Digital Camera
Autofocus problem
Does this problem still exist when you have the shutter pressed halfway down?
Jun 15, 2008 | Nikon D40x Digital Camera
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Nikon D40 will not autofucus.
Check if the swithch on to your left on the lens set to 'A'. If it is set to M this will be in manual mode and autofocus does not take place.
If this doesn't help, try removing the lens and re-fixing it firmly and properly.
Trust this helps.
Dec 16, 2009 | Nikon D40x Digital Camera
My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
Oct 14, 2009 | Sigma 70-300mm f/4-5.6 DG Lens
I have a nikon d-40 is there a seeting on it that well let the cameras lens focus when you push the button half way down. I took picture but I had to manual focus I don't know if it the lens or this camera...
Any of the autofocus settings will attempt to focus when the shutter is pressed halfway. What lens are you using? If it doesn't have an internal focus meter, then the D40 won't autofocus with it no matter what. If it does have an internal motor, then check to make sure the lens is set on autofocus.
Check Custom Setting 12. If it's set on AF-On then the shutter button won't focus.
If this doesn't fix it, specify the lens and any other details.
Oct 09, 2009 | Nikon D40x Digital Camera
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
Jul 14, 2009 | Nikon D40x Digital Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Nov 25, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
376 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
