Question about West Bend 41125 Hand/Stand Mixer
Can you unlock a sony ericsson w880i for free?
  • kray0933 Apr 08, 2009
    i have tried my best to find on internet how to unlock my w880i phone for free currently its on vodafone hope somebody could help me to unlock my phone for free.
    Sergeant:
  • 379 Answers
How to unlock - http://www.youtube.com/watch?v=N-NC40CPKsA&feature=related
Hope I helped Dr Reed
Posted on Apr 05, 2010
How do I free my bowl; I inserted it crooked on the track and cannot get it free. What do I do? PLEASE HELP! I need to use it again soon!!!
Make sure you know which way you need to turn it to release it and then thump the handle in that direction with the heel of your hand. There is not really any other way that to "unscrew" it again.
Dec 18, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid unlocks
By unlocks I have to assume that the mixer head can be lifted up during operation (yes that's really messy ans in some cases maybe even dangerous) I have to assume that you also mean the the head lock switch is not engaging, You have to take the mixer apart to re attach the mixer lock switch. There are several really good videos on youtube that shows step by step procedure for taking the mixer apart. you will see the switch when you have the mixer apart. tighten the screw down tight enough to make the switch engage again. Re-assemble the mixer.
Feb 11, 2013 | KitchenAid 32685 Mixer
Can't get the pin back in the stand of my ksm90
It will go back in, you just need to line it up properly. I hold the headlock in the unlock position while doing it.
Dec 27, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Where do you have the repair center near Princeton, NJ 08540
Here is the only service center in NJ:
New Jersey
Ranft's Denville Vacuum & Appl.
12 Broadway
Denville, NJ 07834
Phone: 973-627-1156
Fax: 973-627-9755
KitchenAid warranty informationif you need it:
If your countertop appliance fails for any reason during the first year, KitchenAid® will replace it FREE OF CHARGE. Our Hassle-Free Replacement Warranty includes:
Delivering a replacement appliance to your door - FREE of charge, Picking up your failed appliance; and Guaranteeing the replacement product for one year.
For more information on warranty replacement, please call 800-541-6390 Direct Factory Service is available following the warranty period. To arrange for factory repair and return, please contact 800-961-0959, ext. 2865 Monday - Friday.
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Ksm90 mixer won't unlock
Look for a reputable dealer that repairs KitchenAid mixers. It is worth the little extra money to keep it going well. I had a much needed repair 15 years ago...... it was 8 years old then, and it is still in great shape and working superbly!!
Aug 15, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Searching for free kitchenaid service manual
The direct URL to the Kitchenaid Service Manual may be found below:
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Jul 04, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The lock/unlock button will not lock. It remains
Without being able to see it try this. Unplug the machine. Place it on a towel on it's side and look up inside the base neck. There's a set screw at the top. Unscrew it 3 to 4 turns and twist the head as much as you can back and forth. See if it locks. Tighten the screw.
If not the pin may be bent to one side and won't drop into the slot. Does the pin lower with the head up? If it does take a pair of pliers and while viewing it from straight on bend it gently so it lines up with the slot on the neck of the base. If that doesn't work it probably has to come apart to see if the linkage is bent or has come apart inside.
Apr 11, 2009 | KitchenAid K45SS Classic Stand Mixer
Replacement of lock and unlock lever
Look for my posts on "Removing the motor cover". The lock is under the motor head. Its easy to find and fix.
Jan 02, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Sunbeam mixmaster jammed, will not tilt back
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Dec 28, 2008 | Sunbeam 2346 Heritage MixMaster Series...
West Bend 41125 Hand/Stand Mixer Logo
2,853 people viewed this question
Top West Bend Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a West Bend Food Mixer Expert? Answer questions, earn points and help others
